Question about Rotel Audio Players & Recorders
Rotel RHB-10 amp channel not working
The left speaker channel is giving out no sound
Posted by Damien on
  • AK47
    AK47 Jun 14, 2014
    Hi Damien , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    have you checked the fuses if yes just work your amp for 10 minutes with a 30 minute break betwen them let me know the results
AK47
    New Friend:
    Problem Solver:
  • 9 Answers
YOU ARE NOT RIGHT IT SHOULD GIVE AT LAEST A LOW VOLUME SOUND WITH A LOT OF DISTORSION AND A CRACKING NOISE IF DOES I GUESS THAT YOU HAD THIS AMP IN A PLACE WITH A LOT OF HUMIDITY AND YOU HAVEN'T WORK IT FOR SOME TIME IF I AM RIGHT PUT YOUR AMP IN THE SUN AND WORK IT FOR 10 MIN WITH A 5 MIN BREAK LET ME KNOW THE RESULTS
Posted on Sep 03, 2014
5 Related Answers
Duncan
Mike Duncan
  • 219 Answers
SOURCE: Rotel RA 9808X Amplifier
I'd suspect that one of the two output transistors on that channel has gone bad. If you are unsure how to test or troubleshoot this, then you might try replace both the NPN and PNP outputs and catch the bad one that way. If your amp uses an output module then you would of course have to replace the module which would replace all the output transistors on both channels. Good luck. Another thing to look out for, is the emitter bias resistors. They are the large white ceramic ones near the outputs. Sometimes one of those will open up too. They will be of a very small resistance value like .5 ohms (point five ohms) or something in that general ballpark, and have a wattage value of typicaly 5 watts. So they are pretty big resistors. Be sure to check them all even if you do find a bad output transistor. They will often go out with the transistor. Good luck.
Posted on Jan 18, 2007
Anonymous
  • 21 Answers
SOURCE: rotel ra-820 amp speaker ports dieing
You may have blown a fuse on the left channel due to speaker wires shorting or a defective speaker. If there are no fuses on the rear of the amp there are probably internal fuses. They are usually glass with a small wire running from end to end. If the fuse is blown the wire will be broken. Replace with the same value of fuse.
Posted on Aug 27, 2007
zimo
SOURCE: Rotel rx 1050...Not working
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
Posted on Feb 12, 2008
Anonymous
  • 319 Answers
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Posted on Apr 17, 2008
Anonymous
SOURCE: Speaker Loss Of Sound
Works great after this solution with the cables.
Thanks
Posted on Jan 22, 2009
Rotel RHB-10 amp not firing up anymore; protection light/cicuit not engaging
Check the rest of the power supply, for example the transformer if there is no power at all. If you are getting some indication of power, check the voltage regulator circuit.
Dec 19, 2015 | Rotel Audio Players & Recorders
Tip
REPAIR ASSISTANCE
ROTEL RA 980BX
Fault: No output from left channel. The right channel is working fine.
Added some photos and circuit for reference
While testing the amp noticed that the left channel is giving switch on off thump while powering ON and OFF the amplifier. It happens when there is DC voltage flow through the speakers. It shouldn't be there. And the thump is there only on the left channel. While testing the amplifier section found that all the transistors where idling at mentioned voltage. All Base pins where around +/- 0.5volt. and the output is almost 0.012mvdc.
FOR MORE DETAILS CHECK THE LINKS
http://electro-medical.blogspot.in/search/label/ELECTRO%20MED%20SERVICES
on May 17, 2015 | Miscellaneous
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
I have a rotel rb970bx. I have 2 and ran them in mono driving a speaker each. I tried to biamp the speakers with one amp driving the tweeters and one the woofers. This worked for about 4 minutes at 1/4...
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Dec 21, 2017 | Rotel Audio Players & Recorders
Help with my power amplifier
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
Oct 08, 2008 | Rotel RMB-1095 Power Amplifier
Apr 13, 2008 | Rotel RMB-1095 Power Amplifier
Rotel ra-820 amp speaker ports dieing
Aug 27, 2007 | Audio Players & Recorders
Rotel Amp center channel out
if you say you checked the wireing ,did you check the speaker. disconnect on of the other speakers and connect up the center to see if you get sound. still no sound speakers bad. Got sound try unpluging unit for a couple of hours then try it again. still no center . Time for the repair shop. Good Luck
May 26, 2006 | Rotel RMB-1095 Power Amplifier
262 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
