My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
Posted by Paloma Duran on
azsnoopy1
    New Friend:
  • 31 Answers
Are you perhaps using component cables to hook the dvd to the tv? Sometimes if you have the blue switched with the green, it will make the picture b&w
Posted on Sep 18, 2015
ernesto cuadra
    Top Expert:
  • 12,223 Answers
Follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Posted on Nov 15, 2012
    5 Related Answers
    Anonymous
    SOURCE: Black & White picture
    This worked for me push your n/p botten to NTSC then go into setup and put your generl SPDIF output to SPDIF/RAW and then go over to video and make sure your compontent is off hope this helps
    Posted on Sep 22, 2007
    Anonymous
    SOURCE: NO color output
    DAV-DZ3k is a good sony product especially ...famous for book shelf speakers,the problem is basically due to the cables used to connect video terminals or the TVcircuits is not proper with the av receiver.. Thank you Regards Sambhu Dayal
    Posted on Oct 07, 2007
    Bubbabear64
    Tim Babcock
    • 2794 Answers
    SOURCE: DVD Player won't play movies in color
    It could be the av cables being faulty or shorted. Try replacing them with another set and see if it goes away.
    Posted on Jul 21, 2008
    kirtec auto
    • 1348 Answers
    SOURCE: VHS plays in colour and DVD plays in black and white.
    there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
    it is called a color killer and needs to be adjusted.
    it is for a technician to do.
    it operates off the 3.58mhz color subcarrier.
    Posted on Aug 18, 2009
    Anonymous
    SOURCE: Picture only shows in black & white when playing DVD
    Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
    Posted on Jan 26, 2010
    Is phonak tv link compatible with panasonic tv model no TC-L32C5/TC
    Here is the User Manual with instructions on all the different types of connection between TV and your Phonak:
    https://www.phonak.com/content/phonak/us/en/hearing-aids/accessories/phonak-tv-link/_jcr_content/mainpar/downloads/productdownloadspar/download_1/file.res/User_Guide_TVLink_II_029-0313.pdf
    And here the backside plugs on the Panasonic TV TC-L32C5/TC
    http://hdtvparts.net/images/thumbs/0018428.jpeg
    0018428-nlghvomyijflbn1hsbdsdrij-3-0.jpeg So you can use the Audio In or the RCA cable connection!
    Hope it helps;)
    Feb 06, 2018 | Panasonic Televison & Video
    Only the right side of my Panasonic Plasma TV (TC-P50UT50) is displaying. The left is is black with some white flickering lights. Sound and video on the right side are perfect.
    Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
    To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
    Oct 01, 2015 | Panasonic Viera 50" Class 1080p Full HD 3D...
    PANASONIC TH37PX POB DVD ONLY PLAYS IN BLACK AND WHITE
    alot of times u need to change the settings in your dvd player it has 2 video setting it will have 3 options pick auto and u will get colot its in your dvd meue not the tv....................
    Feb 08, 2013 | Panasonic TH37PX60B TV
    When playing DVD on panasonic plasma TV, the color is black and white
    Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
    Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
    My pan 32lcd, tc-l32c5 turn off by itself
    Pan has an ECO feature that automatically turns tv off if no buttons pushed for 3 hours. Check Menu to make sure this feature is turned off.
    Oct 13, 2012 | Panasonic TC-L32C5 VIERA 32" Class C5...
    Panasonic DVD-S35S is playing DVD's heavy green tint on Panasonic Plasma HDTV TC-P50S30
    The DVD should be checked on a different set to make sure that it is the problem.
    Mar 11, 2012 | Panasonic DVD-S35S DVD Player
    When I play a DVD, it is in black and White. When I play the tv it is in colour. Can't get the DVD to play in colour!
    You have one of several possible problems, ranging from best case scenario to worst case scenario:
    A DVD video that is supposed to be black and white - try a different disc.
    Some setting on the DVD player is set to monotone - check manufacturer's instructions
    A bad set of cables connecting the dvd player to the tv - test a known good set of cables
    A bad output on the DVD player - test DVD player with a different TV.
    A bad input on the TV - try another input if possible, test TV with a known working video input.
    Sep 17, 2011 | Computers & Internet
    Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose...
    I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
    Jun 27, 2010 | Panasonic TC-P42U1 42 in. Plasma HDTV
    figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
    Oct 14, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
    Televison & Video Logo
    184 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
