SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
SOURCE: kitchen aid wall oven kebs177dssp
call whirlpool tecnical assitance see if they have a kit for it tech knows parts people dont most of time they do beleive or not they want it to work right been working for the factories for years and they doo care
SOURCE: imperial 24 self cleaning oven
Give it a strong verbal thrashing! If that doesn't work...resort to violence!
SOURCE: self cleaning
Sometimes, according to what I've seen. My theory is that the elements are probably covered in grime and this causes the damage. As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours. Longer and you could burn them up, too.
I have heard that with this model, the self clean will ruin the electircal components. It sounds like you may need to have someone test it out to find what is ruined. If I were to guess I would say its the controller board. Mine was on backorder for 2 months.
There is a person in this link that has the same issue:
http://www.consumeraffairs.com/homeowners/kit_stoves.html
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
