Try taking off the back covers of the machine, especially the bottom back cover. It may allow you to look into the tray from the back of the machine and allow you to see what is obstructing the tray from being pulled out. Good luck.
There is a sensor lever that gets stuck on these models. The sensor is located just below the drum . (might be on its own door cant remember) it should move freely if it is stuck in the jam position the jam wont clear.
If you still nee help reply and I will try and assist futher.
Good Luck
make sure all paper is removed from paper cassettes. check all doors covers it is telling you to check. check fuser. you may have a swithc broken, bad or knocked out of position.
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
