Question about Andis Styliner SLII Hair Trimmer
Andis Styliner 2 is not cutting it slightly pulls the hair
Khanh Le
    New Friend:
This styliner is crapt. I buy new clipper, right out of the box it doesn't cut, put a new blade on it, same thing. It doesn't matter how you adjust the blade, it does not give sharp line, and hard to do shape up. Andis Sucks.
Posted on May 01, 2019
5 Related Answers
Anonymous
SOURCE: i took apart the blades of my Andis Styliner II
GET A ******* LIFE AND A NEW BARBER *****
Posted on Jul 12, 2009
Anonymous
SOURCE: My Blades won't move.
GET MONEY MONKEY DAT IT
Anonymous
  • 32 Answers
SOURCE: Misses hair when cutting
try adjusting the screw on the side of the clipper
Posted on Oct 08, 2009
Anonymous
  • 61 Answers
SOURCE: My andis agc2 clippers will not cut hair now.They
clipper and blade simply needs adjusting
Posted on Dec 28, 2009
SOURCE: My andis t-outliner keeps pulling hair when
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Posted on Jun 20, 2010
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
Jun 08, 2010 | Andis 01690 Hair Trimmer
How do i get blades closer on the pivot pro t liners
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
Oct 04, 2009 | Andis T-Outliner Hair Trimmer
Loud
There is a power management mechanism on the side opposite of the power switch that looks like a circle with a **** in it. To set this to the optimum setting, plug the trimmers in and cut it on. Next, your going to use a flat head screwdriver to turn the knob clockwise until it clatters continuously. Next, you turn the know back in the other direction slowly until the clattering stops altogether. Now, the "noise" should be gone and your trimmers are set to perform as they did when you first bought them.
Aug 10, 2009 | Andis Styliner SLII Hair Trimmer
It keeps geting hot every time i cut my hair
you should put clipper oil where the blade contacts it's base (near the middle of the base) and spray kool lube or a similar product on the cutting edge.
Aug 08, 2009 | Andis T-Outliner Hair Trimmer
Replaced with new blades, and now not cutting
 The protective film is still on the blades.( spray with clipper cleaner while running the clippers) Or there's a hair between the blades.......same fix
Mar 18, 2009 | Andis Styliner SLII Hair Trimmer
Andis Styliner SLII Hair Trimmer Logo
643 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
