Question about Yamaha RX-V673
Yamaha RX V673 airplay problem
The receiver is visible on my home network, it has a fixed IP but is not visible in itunes on my laptop so airplay does not work, how can i fix this?
r_ocon
    New Friend:
Disable IGMP filter on your router
Posted on Dec 18, 2012
4 Related Answers
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Posted on Dec 29, 2009
Testimonial: "great feedback. "
Anonymous
  • 236 Answers
SOURCE: Yamaha RX-V 800
Go to yamaha service direct they should have the parts. impossible for this model to be phased out. this is a model about 6 years ago only. they still have the parts for that. Power output and driver transistors are industry standard, replaceable too byt other newer model. you just need to find a real good techie for yamaha... i mean yamaha expert
Posted on Mar 19, 2008
Anonymous
  • 144 Answers
SOURCE: on zone 2 of my yamaha rx v663 receiver it says fixed when I try to adjust the vlume and won't let me cut it up or down.
Check the setup menu of the receiver on zone 2 settings most likely the error is a fixed volume setting for this zone. If not found, reset factory settings and try to setup everything again. If the problems persists, contact your vendor if still under warranty.
Posted on Apr 17, 2009
Anonymous
  • 8 Answers
SOURCE: No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Posted on Sep 07, 2009
My RX- V673 Yamaha receiver won't turn on. I have power and the stand by switch is on
Try holding the 'tone control' and 'info' buttons and press power. This will unlock it if it is protect mode. If it turns back off right away, then you most likely have a problem in the amp circuit which needs to be repaired.
Jan 17, 2017 | Yamaha RX-V673
My marantz sr6006 keeps cutting with airplay audio
Airplay can be sketchy, distance from source and walls can effect it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 29, 2016 | Marantz SR6006 Home theater receiver...
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
Where do you find IP address
Internal Ip address can be found by the following steps
1)Go to start menu
2)choose run
3Just type cmd into the search box
4)Command prompt will appear
5)type ipconfig
it will show your IP address of your system.
External Ip can be traced out using Ip-details.com .
Nov 05, 2013 | Yamaha RX-V673
Yamaha Receivers have International Warranty?
Just send an E-Mail to Yamaha's customer service section. I'm certain they will be able to tell you.
The only other problem you might encounter is if the USA model uses a different mains system to the one in Brazil.
Jun 01, 2013 | Yamaha RX-V673 7.2-Channel Network AV...
My sub wont power off when I turn off my Yamaha RX-V673
The sub would have to be getting AC power from an outlet on the Yamaha
Jan 08, 2013 | Yamaha RX-V673
Yamaha receiver will not connect to Airplay
I have the same problem, it seems the airplay connection is easily lost, it never plays for longer than an hour without itunes losing the receiver, then i have to reset the receiver so that it appears in itunes again, very annoying. I spoke to Yamaha and they are not aware of any issues but clearly there is one. A quick workaround is to bring the receiver up in a browser by typing in its IP address, go to IP Address tab and simply apply without changing anything, this causes the receiver to initialize its network function as you will see the amp resetting and it will then appear in iTunes. This doesn't work through the units setup without changing settings and then changing them back again. Hopefully this is just a glitch that will Yamaha will fix in the next firmware update, I am running 1.14 update.
Sep 28, 2012 | Yamaha RX-V473 5.1 Channel Network AV...
Yamaha RX-V673 Logo
1,960 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
