Question about Jet Tech Systems X-33 - Dishwasher, Undercounter, low temp. chemical "
Keeps filling and draining
This unit will take in water and immediately drain it out. Also in the process the chemicals to wash will pump in and will go through all the functions even though there is no water in the machine?
Posted by Louise on
1 Related Answer
SOURCE: jet tech washer 737 dp
Ouch.
Before you start changing all sort of parts, correct your problem with the wires. You may have to change most of them, depending on how bad the chemical burned tru them.
A good cleaning is required because that soap is going to continue chewing on those wires.
You're right about a short causing other component failure. But first repair those wires
Robert Marsolais
Posted on Aug 01, 2008
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Can you tell me what error code E12 is on a Bosch vision 300 washer?
I am not quit sure if my answer will help you, but I am going to tell you the cycle
The unit fills to whatever water level you choose to use
After reaching the water level the the wash begins, after 20 or 30 minutes of washing it needs to drain the soapy water. The drain pump turn on draining the water, after draining the unit fill back up to the settings and or sprays water while doing the draining and spinning to remove as much dirty water as possible from the first wash. After the first draining, fills back up again for the final rinse and the final drain
The symptom you are describing, here tell me, that issue is with the drain valve, drain hose, the sewer, or is a big possibility that there is is a sock or woman garment stuck in inside holding the rotor causing the water not drain inside the water valve, if the sensors are not sensing the opening of the pressure switch after the first fill. it will not continue This units lately has been added many sensors the only thing this unit doesn't has is the ability to speak but if using common sense you can get to the part that needs to be replace. You need to read and understand the wash cycle first.
Nov 24, 2017 | Bosch Washing Machines
On Maytag top loader, water enters but drains immediately.
check that the drain hose is above tub level
check for faulty program board engaging the pump all the time
Sep 20, 2016 | Maytag PAV2300 Top Load Washer
Why when we start the wash the water goes in and drains right out so it just keeps doing that
check your drain hose going to the drain pipe in the wall. if the drain hose is lower than the highest water level on the unit, it will cause a siphoning issue. water will run into and the never fill enough to start into cycle. If unit is filling and the drain pump is on at the same time it is filling, then it is a bad control board.
Feb 12, 2015 | Amana Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
Dishmachine will not hold water. Its draining as you fill it?
0
Does not hold water Faulty #3 micro switch (drain) Replace switch, P/N 00411.00
Clogged or defective drain valve Clean and/ or replace drain valve, P/N 04113.00
Nov 11, 2011 | Cma Dishmachines L-1X Dishwasher
The unit fills with water and then drains immediately, no wash...what could cause this?
Try to clean the discharge pump filter first (Instructions in the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out this posting:
http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
Feb 27, 2011 | General Electric WCVH6800J Front Load...
The washer fills but before it agitates the water pumps out and then keeps repeating this process. Once in awhile it agitates for a short time.
This is an easy fix. Your drain hose must be 30 inchs above the floor. If it is not at least 30 inchs above the floor, gravity will drain out the water at a given point and then the water level will drop sufficiently for pressure to cause the motor to stop and the water valve filling again. Simply make an adjustment on the placement of the drain hose to prevent the auto siphoning of the drain hose.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2009 | Washing Machines
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Jet Tech Systems X-33 - Dishwasher, Undercounter, low temp. chemical " Logo
41 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Colin Stickland
Colin Stickland
ray gallant
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
