SOURCE: Nikon d40x LCD screen stopped working
Have you tried the 'Menu' button? If you've turned off 'Review' in the settings menu, the screen doesn't show anything after you take a picture. If the screen doesn't come on when you push the 'Menu' button with a charged battery installed, your camera will need to be repaired.
SOURCE: Nikon d40x shutter stuck
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
SOURCE: My Mac won't detect my Nikon D40x
I recommend you getting a card reader, then you can download your images and don't wory about it detecting your camera. Its easier and quicker.
SOURCE: nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
SOURCE: removing battery chamber cover, nikon d40x
tilt the battery chamber cover by some 45 degrees, and then just snap gently to pull out
