Question about Hitachi 50V720 Television
"No Sync Signal" on both component inputs
Both component inputs produce no picture. I have cable and a 360 hooked up which worked fine for a long time then stopped. I tested the cables on another television and the picture came through fine. The HDMI input works, the AV input works, but not the component. Is it possible to wearout the inputs? Is the a internal computer problem? I'm at a loss. Please help!
Posted by nmxman on
Lawrence Oravetz
  • Hitachi Master
  • 10,548 Answers
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Posted on Sep 14, 2017
4 Related Answers
Anonymous
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
Anonymous
  • 1077 Answers
SOURCE: Hitachi 50V720 No sound with HDMI - no Component video inputs
Right now there seems to be many people with the same TV problems with sony and HDMI cables. Most of the solutions are resetting the TV and sony product. Try leaving your TV unplugged for a hour to let it reset itself.
Posted on Feb 17, 2009
Anonymous
SOURCE: No hdmi signal
hold down your playstation button for a few moments and it will automatically sync to the tv at optimal settings. And thatz wut it doobi
Posted on Dec 31, 2009
Anonymous
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Posted on Feb 21, 2010
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
Video Issue with Onkyo 606 when trying to watch Cable TV.
When this happens and you just see the input label try to press the power button on the front of the cable box and see if it brings the picture up. If this does produce the picture then it is a good possibility that something is interfering with the remote communicating with the cable box. I don't know if you have it contained in an entertainment center or how you have placed your equipment but if there is glass try to clean it and also wipe down the front of the cable box and make sure there is an unobstructed view of the front of the cable box.
Good Luck.
Dec 09, 2009 | Onkyo TX-SR606 Receiver
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
No Picture, Only sound
You need to tell the PS3 that you are now using the new video method. It is still trying to output video on the yellow cable, not the component. If you go to settings>video and tell it to use component, and then switch the cables real quick, it should work.
An easier solution is to do a backup from the system menu, then a "restore" (quick restore is fine), and then power it off, hook up the new cable, and it will detect the video method when it turns on for the "first" time (since the restore).
You do have component input on your TV, and that is the input you are on when you are trying this, yes?
Jul 22, 2008 | Sony Playstation 3 (PS3) Console
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Hitachi 50V720 Television Logo
959 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
