Question about Nikon D60 Digital Camera
I have a nikon d60 and cannot get the pop up flash to work, any help would be appreciated.
Posted by wbaskin1995 on
William Miranda
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
There is a button just to the left of the flash on the camera that should pop up the flash or if you are in auto mode it shoud pop up by itself.. if these do not work then your flash is stuck and you could just pull up in it and it should open but I dont recommend that just in case you break it.. but I have done that several times
Posted on Nov 15, 2012
5 Related Answers
Steve5
Steve Grezoux
  • 423 Answers
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
Posted on May 30, 2009
Anonymous
  • 71 Answers
SOURCE: need to change language on Nikon D60
Within the menu items that can be viewed on the back of the camera, there is a language option that you can set. You may have to scroll through all of these to get the correct setting. Nikon tends to change the menu layout from camera to camera, so it may not be the same in your D60 as it is in a D300 or other model.
Posted on Jun 03, 2009
Anonymous
SOURCE: Flash on Nikon D60 does not work
Hello. When i first bought a D60, it was working perfectly outdoors at day and would work without a hitch with external flash. However, the internal flash would never get released. No menu option would be of any use, only symptoms were flashing 'flash' and 'question mark' symbols in the finder. NIKON service fixed it - There was nothing wrong with the camera electronics. The little flash release mechanism somehow acted up and NIKON staff fixed it in +- 5 minutes. I do hope you have yours in full working condition by now.
Posted on Jun 04, 2009
Anonymous
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Posted on Jun 20, 2009
  • 102366 Answers
SOURCE: Would like to know how to use the self timer on my Nikon D60?
Highlight Release mode in the Quick settings display and select the self-timer mode (an icon that looks sort of like a one-handed clock). Frame the photo. Press the shutter release button halfway to focus, then all the way to start the timer.
It's all in the manual under "Self-Timer and Remote Control Modes," page 55 in my copy of the manual.
Posted on Jun 14, 2010
D60 flash won't pop up
Please set the MODE to P (Programmed Auto) In this mode YOU control the flash, not the camera. Inside where it is not bright. Set your ISO to 800 and take a photo indoors with low light. Then pop up the flash and do it again. P lets you take a photo with the flash down or UP it is the only mode I suggest most people should use. :)
Jan 15, 2017 | Nikon D60 Digital Camera
My nikon D60 and the pop up flash dosent work
the flash pivot on the release side of the flash has a small cylinder that operates the flash up switch. If that cylinder is broken off or the pivot is pushed in so the switch doesn't close, then what you describe happens
pop up the flash and remove the two screws underneath, and you can pry off the cover - gently - to check the switch
Mar 16, 2013 | Nikon D60 Digital Camera
Could the Sakar Dedicated Ittl Flash work For Nikon D60
Probable will not work on the Nikon's hot shoe because the contacts on the Sakar flash gun won't match the contacts on the Nikon's hot shoe.
You can use the Sakar flash gun as a slave flash by connecting a optical flash trigger to the Sakar flash gun and use the Nikon's flash to trigger the Sakar slave flash.
Feb 27, 2013 | Sakar Dedicated Ittl Flash For Nikon D60...
I have a nikon d60 and cannot get the pop up flash to flash, any suggestion
Go to menu then custom setting menu then turn your built in flash on problem solved
Nov 13, 2012 | Nikon D60 Digital Camera
Hello i have nikon d60 and the flash do not pup out
In what mode(s)? In the point&shoot modes the camera decides whether to pop up the flash. In PSAM modes you decide.
Dec 25, 2009 | Nikon D60 Digital Camera
Have a nikon d60 and the flash will not go off even when in a dark situation. Pops up but no flash?
if it pops up then the sensor is working and the mechanical parts are working,
Next is manual force flash test, if is manually flashes, the bulb is good else replace the bulb.
Sep 05, 2009 | Nikon D60 Digital Camera with 18-55mm lens
May 19, 2009 | Nikon D60 Digital Camera
Built-in flash not working
Please shoot in P mode. In P mode it will use the flash if you pop it up and not use it if it is down.
The flash uses LOTS of battery power. If you battery is weak the flash may take a long time to recycle (charge).
The Flash must be popped up and READY before you can use it. The flash is charged or READY when the RED light is on.
I hope this helps.
Apr 03, 2017 | Nikon D60 Digital Camera with 18-55mm lens
Nikon D60 Digital Camera Logo
80 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Nikon Camera Expert? Answer questions, earn points and help others
