I want to restore my paker bell computer to an earlier date but there is no such date on my restoring point to set my paker bell to.how do i set the date manually?
SOURCE: System Restore...
System Restore is a valuable tool Microsoft released with Windows Me and substantially enhanced with Windows XP. (Windows 98 users can only gain this functionality with a third-party program.) Although it is not a backup utility per se, it performs a valuable backup function. System Restore monitors a wide variety of system and program files and creates a backup (called a restore point) of them at predetermined intervals. If a user experiences a problem with his system, he can roll back (restore) the system to a previously working state. By design, System Restore does not monitor data files. Consequently, you cannot use System Restore as a backup utility. Nevertheless, its significant value as a system backup tool makes it worthy of inclusion in this section.
Users cannot control many of System Restore’s parameters without manually making dangerous system edits, but they can adjust a few of its settings, such as how much room the system allots for restore points. In addition, users can manually create, invoke, and undo restore points.
In WinMe and WinXP, System Restore monitors and records changes to EXE (executable), VXD (virtual device driver), DLL (software and hardware drivers), and Windows Registry files. (Drivers are small programs that let system components communicate with a computer. The Registry is a database containing information about the system and user configurations and settings.)
System Restore periodically saves this information in a compressed archive and stores it on your hard drive. According to Microsoft representatives, System Restore makes an automatic checkpoint approximately every 10 hours your computer is running. The system must be idle for two minutes before it can create a checkpoint. If System Restore cannot create at least one checkpoint within a 24-hour period, it will attempt to create one at that interval. However, the system must also be idle for two minutes before it can create a 24-hour checkpoint.
Users of both WinMe and WinXP access System Restore from the System Tools menu (click Start, Programs [All Programs in WinXP], Accessories, and System Tools). When the main System Restore window opens, you will see two or three choices. The first two, Restore My Computer To An Earlier Time and Create a Restore Point, are present in all cases. The third option, Undo My Last Restoration, is present only if you have previously restored your computer to an earlier state. WinXP users have another option on the left side of the window: System Restore Settings. This option opens the System Properties dialog box you used in the “Give yourself room” and “Turn it off” sections.
SOURCE: windows cannot check for updates
Backup your important info, then order your recovery disks through the manufacture and do a COMPLETE restore...
SOURCE: packard bell restore new Hdu
From parkard bell suppport website Quote
"Step 4 - Re-installing your software
Call the help desk and ask them to guide you through the
ExtHS process.
Please have your Recovery CDs to hand when you call
the Easy Repair line.
Once you have completed the ExtHS process you will
need to re-install Windows and the other software supplied
with your Packard Bell computer. To do this follow the
steps below:
1. Disconnect all peripheral devices (web cam, printer,
scanner, broadband modem etc.).
2. Insert the Packard Bell Master CD 1 / DVD in the top
CD / DVD drive and restart your computer.
3. The CD will load and display the following message:
Please refer to the section headed Packard Bell
Recovery Program in your user’s guide for instructions
on this utility. Press OK if you want to continue
or Cancel to return to DOS.
4. Press the letter O on your keyboard to continue.
5. You will see a menu with options. Please select option 1
“Standard System Restore” by pressing the 1 key on
your keyboard.
6. A warning message about data loss will be displayed.
Press the letter O to continue.
7. The process will take around 40 minutes. Once this is
done you will need to restart your PC. Remove the CDs
and store them in a safe place.
8. If there was a Software Library DVD supplied with your
PC you can use this to install the extra software that was
supplied with your computer. Insert this into the drive
and follow the onscreen instructions.
9. Finally, you will need to install any additional devices
(web cam, printer, etc.) and software by following the
instructions supplied with them."
SOURCE: we put in sp3 for
load a startup boot disk from dos. type in "format c:" and then try using your system recovery disk again.
hope this helps
SOURCE: I am trying to restore
If the Recovery Process doesn't work maybe you can purchase replacement CD's. Try contacting PB to see if replacements are available.
