Brother Ink for Dcp-6690cw and Lc-1100 Logo
Naveen Kumar Posted on Nov 13, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset counter in brother dcp6690cw - Brother Ink for Dcp-6690cw and Lc-1100
Printer Help & Support
Level 3:
  • Brother Master 783 Answers
  • Posted on Feb 14, 2014
Brother Master
Level 3:
Answers
783
Questions
0
Helped
279934
Points
1637
Sir/Madam
It's Very easy to reset counter in brother Printer,I suggest You watch YouTube video For Your Brother Printer Problem,I Hope You resolve and get all Brother Printer Help after watching this video URL Link below:
How to Reset Purge Counter on Brother DCP J315W Printer
Or
In case You still need Help I suggest You Follow Us On:
Brother Printer Support
How to ram clear
Does this happen when you are printing or scanning?
Try to power off, unplug printer and power back on.
See PDF fromBrother:
http://www.brother.ca/en/products/pdf/manuals/MFC440CN-UG.pdf Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
I have a Brother MFC-9180, it has a DR8000 in it. The machine come up on the display saying "Change drum soon" which I have done, the new drum did not come with a page to feed into the drum. I want to...
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
Or Try this:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002800/000037/faq002837_009.html?reg=as&c=au&lang=en&prod=mfc7220_us_as
EXPECTED LIFE OF A BROTHER DRUM-DR520
reset drum counter
1 hold down go button 30 second all light off than press 3 times go button.drum counter reset. after 20,000 page need reset drum counter.
3helpful
2answers
Hi, I have a DCP6690CW Brother printer and have had some trouble with paper jams today, I have cleared the jam and now the display tells me "Unable to print 70". please advise, thanks Email:...
If you were sucessul in clearing the jams , it seems possible that this was done with the power connected and so it might have distrubed the communication of the printer drivers. so it might need a reset and so remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and then connect the Printer to be detected and installed as a new hardware. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
1helpful
Reset drum counter for Brother mfc-7225N all in one laser printer?
Brother Drum Reset Instructions:
This works on the Brother DR-510 and many others.
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
2helpful
Drum counter is flashing
The following information is an excerpt (Step 7) from an FAQ on the Brother website found here http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000100/000054/faq000154_029.html?reg=eu&c=pt&lang=pt&prod=hl1440_all&Cat=7&ot=eu_ot
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
11helpful
2answers
Brother HL 1250 Laser. Drum & page counter
  4. close front cover
Norman Weimar
Norman Weimar
k24674
