Question about Avanquest Computers & Internet
Designing labdel sheets for A4 paper
Several years ago when in the USA, I bought MyLabel Designer and used it for printing UK size labels on A4 size paper. Having moved to a new laptop running Windows 7 this program would not run. I therefore bought on line MyLabel Designer Deluxe but found I could not design labels to fit on to A4 size paper. Your UK office have told me that I cannot do what I want and referred me to your US Office. If it is true that I cannot use A4 size paper, can you offer me a refund. I look forward to hear from you. Many thanks.
Posted by Douglas Potts on
5 Related Answers
Anonymous
SOURCE: Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Posted on Aug 27, 2008
goodgold
Sergey Artuganov
  • 389 Answers
SOURCE: How to print CD Lable in HP Office Pro K850 on Sticker paper
The Reason in drum you should change the photodrum.Good luck!
Posted on Sep 20, 2009
ikkenom
  • 10406 Answers
SOURCE: I recently purchased a new HP computor which has
Check that your colour printer has not run out of ink,
and thus cannot "mix" its primary colours to produce the colours that you want.
Posted on Dec 05, 2009
benhansenslc
SOURCE: I am running Windows 7
I have been having the same problem. Following the directions found here http://www.avery.com/vgnfiles/OP/en_us/Help%20Center/staticfiles/DesignPro%20for%20PC%20Help%20for%20Windows7.pdf will mostly help but I am still having other smaller problems. I think I am going to have to phase away from this software overtime.
Posted on May 18, 2011
agongora
SOURCE: JUST INSTALLED MY ADVANCED LABLE DESIGNER ON A NEW
So far, the only solution I have found is the following:
Once theLabel has been designed, click on the Bar Code Button, click on the Data Entrywindow, press the Tab key which will allow more Labels to appear on the IndexWindow to be printed. Click the Tab key to create as many labels are needed toappear on the page to be printed. Note: TheCopies of Each Label setting on the File Print window will not work in Windows7. The Copies ofSets of Labels prints the number of pages desired for that Label.
Posted on Jun 25, 2011
Set up a mail merge for labels avery L7162, but the printer prints them a different size - Printer is HP M3035. It is something not set up on the printer
You will need to feed these through the manual tray and you should set the paper size and type to match this label. The avery site shows this as an A4 label sheet. If you are in North America the default on this printer is letter size not A4.You should also ensure that you have configured the print driver correctly when you go to print.
May 23, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
I am trying to make labels for cd's but they are not printing correctly. The sheets show the cd to the side of the page but it's only printing straight down the middle so it's not letting me print...
I had the same problem. The solution I came up with was to use Microsoft Publisher to print the labels. First I drew a circle about the size of the cd and another inside it for the centre. I printed it out on a plain sheet of A4 paper and measured held it over the label to see how they matched up. I dragged the circles in publisher using trial and error until the circles came out in the same place as the circles of the labels. Then I designed the label inside the circle using publisher and when I printed it on the label it came out in the circle.
If you don't have publisher just check the paper shown in your print dialog and make sure you have changed it to the label type you're using rather than A4 Plain which is the standard.
Jul 27, 2010 | Avery DesignPro Deluxe CD-ROM...
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 20, 2009 | Dell 1320c Laser Printer
Hp officejet j4580 alignment sheet
If you are in the USA then an A4 should be 8.5 inches by 11 inches
So measure 4.25 across a sheet of paper at the top and again at the bottom , draw a line between them
Measure 5.5 inches from the top on one side and again on the other join those lines up you now have a sheet of paper with a cross on it
Photocopy some of off the original and use them to check out the printer.
If you are in any other part of the world the sizes are 210mm x 297mm
Mediface label printer has a built in section to print off such calibration sheets see if you can get an evaluation copy
Aug 22, 2009 | HP OfficeJet J4580 All-In-One Laser...
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Printing labels
You have to feed the labels through the manual feeder.
Aug 23, 2008 | Brother HL 2140 Laser Printer
Computers & Internet Logo
64 people viewed this question
Top Avanquest Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Sheldon Dedek
Bill Boyd
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
