EI400 series
Copy following link to identify Ei400 series programmable countdown timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei200
Hold down ON/OFF button and fully press-and-release small round reset button using paper clip.
Keep holding ON/OFF button until display changes
This timer uses CR2 battery installed in tray below the buttons.
Reset timer after installing new battery.
If functionality is not restored after new battery install and reset, then timer has gone bad.
This timer has 1 year limited warranty through Intermatic for defects in workmanship.
Ei400 can be wired for single-pole or 3-way.
Timer requires no neutral wire since battery operates the timer and relay circuit
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
