Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a briggs and stratton 13.5 hp power engine that wont start. The engine is almost new, oil level is good and when I remove the spark plug cap and dold it near the top of the plug and pull start it I see a decent spark. I have the chock on and have tried fuel all the way on and all the way off but it just wont start. Is there some kind of shutoff switch for the engine that could be off, or if the oil level switch is broken would I still see a spark? Any suggestions?
Richard Lindsey
    Champion:
    Habit-Forming:
  • 211 Answers
There may be safety switches, but if you are getting a spark, that is not the problem. After you cranked with no start, is the spark plug wet with gas? can you smell gas in the cylinder after pulling the plug? It could be that your carb float/needle valve are stuck closed. Try lightly tapping the side or the carb.
Posted on Jun 19, 2017
5 Related Answers
Joe Hogan
  • 10865 Answers
SOURCE: White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Posted on May 19, 2009
Dwain Pippen
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
Anonymous
SOURCE: 24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Posted on Jul 14, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: I have a briggs -stratton 12 h.p. engine on my
Hi and welcome to FixYa I am Kelly.
This post is listed under the Intek V-Twin engine that would be engine model number 281707-0148-01 so I am making my recommendations based on that model number. If your ENGINE model number is different from the one above please respond with the number.
It sure sounds like there may be a compression problem. All other elements
Fuel, Air and spark are in place. If you can not get even a backfire it sounds like there may be a valve sticking open. Probably more than one if not even one cylinder is firing.
I have one question..... Has this engine been sitting unused for a while?
Lets start with something simple. (again based on 2 cyl engine but procedure would be the same for a single cylinder)
1. Remove both spark plugs
2. Spray a very generous amount of WD 40 in BOTH spark plug holes.
3. Use the starter and turn the engine through for about 5 seconds
4. Again spray WD 40 into the cylinder head via the spark plug holes and let it soak for about 15 minutes.
5. Turn the engine through again with the starter for at least 15 seconds. Pause 1 min and then another 15 seconds.
6. With assistance Use your thumb to cover the spark plug hole opening and check each cylinder for compression
Compression = Yes / Install spark plugs and try starting.
Compression NO ... If engine is OHV remove valve cover cap(s) and spray WD 40 through the valve springs onto the valve stems then let them soak for about 15 minutes.
Flat head engine
Remove cylinder head only and check the valve seats for coking in the seats. ESPECIALLY the exhaust valve. There should be a visual ring where the valve mates to the valve seat. If you can not see a visual ring then the valve seats should be hand lapped with valve grinding compound. (Valve Spring will have to be disconnected but NOT removed to hand lap with valves grinding compound)
Once you get a ring that you notice on the valves then reconnect the springs and install the head.
Check for compression with your thumb by having the engine turned through.
You really should have compression at this point.
Install spark plug and start the engine.
If you need more assistance or.. have a different model number other than the one above... then just respond here and some one will help you.
Thanks for using FixYa.
Kelly
Posted on Apr 14, 2010
Anonymous
  • 3 Answers
SOURCE: what kind of oil does the 22 hp briggs stratton
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Posted on Apr 16, 2010
Briggs and Stratton 3000 psi wont start.
did you leave fuel in it for the 30days and how old was the fuel then it is only good for about 30days in small engines
Jun 03, 2012 | Briggs & Stratton 3000 PSI Pressure Washer
I have a Powermate Generator which I bought about 3 years ago from Lowe's. I start it up and run it every few months. Now it will not start. I took the magneto off and cleaned the inductor magnet in...
Remove all the wires at the coil and retest. Good idea to use a new plug for testing or insert metal into plug cap and then hold close to metal of engine. If still no spark, remove the coil and take to small engine shop for free test (may have been damaged by heat if it was making contact with flywheel). I use a growler to test the coil. If retest produces spark, most likely faulty oil sensor. Remove the wire from oil sending unit. Dont replace the oil sending unit, just check oil often.
Sep 09, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
Engine will not start. no spark. oil level is good. ...
There may be a engine control switch on it. It will be on the engine somewhere. it is differnt then a circuit breaker on the outlet panel. It also could be a bad ignition module.
Nov 18, 2010 | Briggs & Stratton Briggs Stratton 30208...
It wont start. Fuels good. Gets a spark, although plug looks oily. Air filter was dirty, have new one. Still wont start with filter off. Tried starter fluid. Manual says maybe excess oil in engine. If so,...
If you have no sign of life with starter fluid, there's no spark in the cylinder.
If the plug is oily, it may spark in free air, but not under compression. Try a new plug first.
Excess oil won't prevent the engine from starting, but it will spew oil everywhere if it's overfilled. Just check the level with the dipstick (on level ground), and pour any excess out of the filler tube.
Aug 07, 2010 | Briggs & Stratton 190cc 875 Series OHV...
I have a 18 hp briggs and stratton engine that will not start
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Kelly
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine was over filled with oil. Lowered the level but now it turns over but wont fire. Like it has no spark
Oil could have gotten up in the cylinder and fouled your spark plug. Remove the spark plug and clean it real good.
Apr 22, 2010 | Parks Optical 13.5hp Briggs And Stratton...
B&S ELS 725 on a Husq 2448 lawn tractor - stoppe running won't st
There is no oil pressure switch to save the motor. You may be ok if the oil level did not drop too low. Change the oil, recharge the battery, put in a new spark plug and fresh gas. You may be lucky and have it start with no damage. good luck
May 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,237 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
ray gallant
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
