Question about Dell Latitude D505 Notebook
Restoring computer back to factory settings
After you restore the computer back to its factory settings do you need to reinstall windows
Posted by Lesley Molloy on
Gerald Manuel
  • 564 Answers
No. restoring back to factory settings means it will be back to when you first got it. windows will be installed along with whatever software and programs the manufacturer put on.
Posted on Nov 13, 2012
5 Related Answers
ecmorgan69
Edward Morgan
  • 280 Answers
SOURCE: dell latitude d620 needs factory restore
Apparently your model of laptop doesn't have a recovery partition. You're going to have to get out the Dell Operating System CD for your laptop, boot to the CD and reinstall Windows the old fashioned way. Make sure the product key on the laptop case is handy.
Posted on Jan 04, 2009
Anonymous
  • 691 Answers
SOURCE: how to restore hp pavilion to factory settings?
Hello
Thank you for using
FixYa for your problem
Restore the PC to original condition with the HP Recovery Manager If the computer cannot open to the Windows desktop, follow the steps below to use the f11 key to launch the HP Recovery Manager and return your notebook to its original factory condition.
  1. When the notebook is powered on, press the wireless button to turn ON the wireless switch.
  2. Turn the power off and on to restart the computer.
  3. Press the f11 key to launch the HP Recovery Manager. NOTE: If the HP Recovery Manager cannot access the hard drive to fix the system errors, use the personal recovery discs to recover the hard drive to its original condition.
  4. When the Welcome to HP Recovery Manager windows displays, click Next .
  5. When prompted to perform a Microsoft System Restore , select No , and then click Next .
  6. When prompted to perform a System Recovery , select Yes , and then click Next .
  7. When prompted to Backup Files , select the desired option.
  8. When prompted to perform a Recover your computer to original factory condition , select Next and allow the system recovery process to complete.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 18, 2009
Anonymous
SOURCE: restore factory settings on a Dell Latitude C510
theres a solution to this. all you do is. hold the ctrl for 20 seconds then as you.
turn power on press f-1 or f-11 botton press f-11 botton 16 times semi guickly.
and follows the promps worry not about any files or music being missed.
theyll all be there.
Posted on Jan 23, 2008
Anonymous
  • 76 Answers
SOURCE: Factory restore for latitude c400
well..that would be a new thing for me. I do not recall any F11 function that will do this. Perhaps he or she has more information on this..
Posted on Nov 21, 2008
Anonymous
  • 50 Answers
SOURCE: I want to restore my dell laptop to factory settings
you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Posted on Mar 25, 2009
I need to restart my computer to a factory settings
1st of all you need to take back up of all your important files and data.
Then Turn off your computer.
Remove everything but the monitor, keyboard and mouse.
Turn on the computer and when see the first screen, press F8 to open the Boot Options Menu.
In the menu you need to find System Recovery Options
Due to every PC different configuration, you need to select Factory Tools and then restore factory setting.
Presses the Yes button and restore system software to factory condition check box and click Next.
After the restore operation is complete, click Finish to restart the computer.
Hope this will work for you ! :)
Mar 24, 2017 | Computers & Internet
How to take laptop back to factory settings
Depending on the brand and year it was made there may be a factory partition that will restore computer back to factory defaults, if not then a reinstallation of windows will be necessary, If factory partition is available just do a search o Google with your make and model # such as : How to restore an Acer Aspire 7425 to factory defaults using recovery partition
Mar 15, 2014 | IBM ThinkPad T40 2373 Notebook
I have a packard bell imedia mc 1538 and need to resore to factory settings, have tried using F10 key with no result just goes to start up. The master cd just does a system restore and not the factory...
If the file that holds the factory settings is gone then there is no way to restore the factory settings back. You can however reinstall windows if you got a hold of a windows disc in the version you want. You can use the windows key on the computer somewhere to activate the windows. I would suggest doing a system restore the the last restore point and removing any unwanted things from there.
May 11, 2011 | Computers & Internet
How to repormat a laptop
Before reformatting the pc you must back up necessary files and applications that you might have. Because during the process all files would be deleted and pc would be back to its factory default. You may follow the steps below to reformat the pc.
1. Turn on the computer. When the Dell logo
appears, press <F8> several times to access
the Vista Advanced Boot Options Window.
2. Select Repair Your Computer.
3. The System Recovery Options window
appears.
4. Select a keyboard layout and click Next.
5. To access the recovery options, log on as a
local user. To access the command prompt,
type administrator in the User name
field, then click OK.
6. Click Dell Factory Image Restore. The Dell
Factory Image Restore welcome screen
appears.
NOTE: Depending upon your configuration,
you may need to select Dell Factory Tools,
then Dell Factory Image Restore.
7. Click Next. The Confirm Data Deletion
screen appears.
NOTICE: If you do not want to proceed with
Factory Image Restore, click Cancel.
8. Click the checkbox to confirm that you want
to continue reformatting the hard drive and
restoring the system software to the factory
condition, then click Next.
The restore process begins and may take
five or more minutes to complete. A message
appears when the operating system and
factory-installed applications have been
restored to factory condition.
9. Click Finish to reboot the system.
Operating System Reinstallation
Before you Begin
If you are considering reinstalling the Windows
operating system to correct a problem with a
newly installed driver, first try using Windows
Device Driver Rollback. If Device Driver Rollback
does not resolve the problem, then use System
Restore to return your operating system to the
operating state it was in before you installed
the new device driver. See "Using Microsoft
Windows System Restore" on page 38.
NOTICE: Before performing the installation,
back up all data files on your primary
hard drive. For conventional hard drive
configurations, the primary hard drive is the
first drive detected by the computer.
To reinstall Windows, you need the following
items:
• Dell Operating System media
• Dell Drivers and Utilities media
Restoring Your Operating System
NOTE: The Dell Drivers and Utilities media
contains drivers that were installed during
the assembly of the computer. Use the
Dell Drivers and Utilities media to load any
required drivers. Depending on the region
from which you ordered your computer, or
whether you requested the media, the Dell
Drivers and Utilities media and Operating
System media may not ship with your
computer.
Reinstalling Windows
The reinstallation process can take 1 to 2 hours
to complete. After you reinstall the operating
system, you must also reinstall the device
drivers, virus protection program, and other
software.
1. Save and close any open files and exit any
open programs.
2. Insert the Operating System disc.
3. Click Exit if the Install Windows message
appears.
4. Restart the computer.
5. When the DELL logo appears, press <F12>
immediately.
NOTE: If you wait too long and the
operating system logo appears, continue to
wait until you see the Microsoft® Windows®
desktop; then, shut down your computer
and try again.
NOTE: The next steps change the boot
sequence for one time only. On the next
start-up, the computer boots according to
the devices specified in the system setup
program.
6. When the boot device list appears, highlight
CD/DVD/CD-RW Drive and press <Enter>.
7. Press any key to Boot from CD-ROM.
Follow the instructions on the screen to
complete the installation.
manuals are here http://support.dell.com/support/edoc...5/en/index.htm
Mar 23, 2011 | Dell Inspiron 1525 Laptop
How do i restore to factory settings for my hp pavilion zt3000 without the cds
There's basically no such thing as "restore to factory settings" when it comes to PCs.
You can restore the BIOS setup to factory defaults, but it's rather improbable that something got messed up there.
To have the system like it was fresh out of the factory, you have to wipe your hard disk and install the operating system (Windows in this case) anew on the hard drive, and for that you need the system reinstallation CD. Then you need to reinstall all the computer-specific drivers and bundled applications that came with your computer. For that you really need at least your Windows CD, the drivers etc. can be downloaded from manufacturer's support websites.
And then all the system updates that appeared for your Windows version over time need to be installed as well.
Nov 26, 2009 | Toshiba Satellite M115-S1061 Notebook
Reinstall windows vista Os
If you are having the a Dell Laptop there is an interrnal restore option where you can reformat your computer HDD and you can put it back to factory settings - Which is called as Dell Factory Image restore --To get in to this option You need keep tapping the F8 Key on the keyboard as soon as you turn ON the Laptop . It will take you to the advanced boot option -- From the List Choose the One which says Repair my computer ---Next you will be getting a screen where it will ask for the Keyboard Layout option Choose Engllish US and Click on the Next it will take you to the Window Where it says System Recovary Option . . From System Recovary option Click on the one which says Dell Factory Image restore that will restore your Computer back to the factory settings after formatting the hard drive ...After restoring the Computer to the factory settings system will restart and then the computer is good to go ...........
May 12, 2009 | Dell Inspiron 1525 Laptop Jet Black
Restore back to factory setting
take any of vista disk(any copy)
boot with cd in repair option get restore click.
Jan 25, 2009 | E-Machines (T2958) PC Desktop
Ibm restore to factory setting
You have not explained what is wrong with your computer.
Is the laptop working, does it boot up into Windows?
What are you trying to restore?
Are you trying to get into a previous Restore Point?
The Access button takes you into the BIOS, you can change the BIOS settings back to the Default settings (ie the factory default settings).
It is difficult to offer a solution without knowing the exact nature of the problem.
Nov 23, 2008 | IBM ThinkPad R50e Notebook
Need to restore my laptop back to factroy setting
hi,
If you have a dell computer, you can restore your computer back to factory settings using CTRL+F11. You need to restart the computer and when you see the Dell logo. Press CTRL+F11. You will see the message "PC RESTORE"
You may reinstall your operating system using the cd if your system doesn't have the capability to restore settings to factory. You may call you computer manufacturer about it.
Keep me posted.
Thanks.
Oct 26, 2008 | Computers & Internet
The quick restore dosen`t work
What operating system you are using before installing windows xp. If it is windows 98, Your restore cd will restore windows 98. if you want to restore to factory settings pls boot from the restore cd and format the harddisk. Becareful, this will erase your entire data on the harddisk which cannot be recover. If you are using licenced (not pirated) windows xp boot from it and reinstall windows xp so that you can run the os smoothly. But in either case becarefull when you are formating, it will destroy entire data and you may endup in soup. feel free to revert back for further quiries
Sep 29, 2006 | Compaq Presario 5000 PC Desktop
Dell Latitude D505 Notebook Logo
1,139 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
