Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
I have a Rheem Electric Water Heater Model 62MV-520 that I need to know how to control the temperature.
4 Related Answers
Anonymous
  • 155 Answers
SOURCE: Rheem Electric 40 gallon water heater not providing heat
The elements may be burnt out you can check them by an electrical light tester. There is a lower and an upper element. If the tester lights up element is good. I hope this helps, please rate if the answer was helpful. Have a great day. Jeff
Posted on Apr 04, 2010
Anonymous
  • 760 Answers
SOURCE: Need Free Manual for Rheem Electric Hot Water Heater
Here is the link to a manual:
http://globalimageserver.com/fetchDocument.aspx?id=f43430fe-a847-4371-b6c7-cab5eb0e34a6
Be sure to have your circuit breaker off before you remove the cover.
220V and water together is not a good mix.
Posted on Jul 19, 2010
Anonymous
  • 235 Answers
SOURCE: how do i replace the heating elements of a rheem
Not familiar with this model but most are generic.
Turn the water off;
Release the pressure with the pressure relief valve and leave it open;
Undo the cold water inlet assembly and drain the tank;
Disconnect the element wires from the thermostat;
The elements are held in by 4 bolts. Undo the bolts and remove element;
Installation is the reverse of above.
Posted on Feb 19, 2011
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: rheem 80 gal electric water heater,model
Hello, tim
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
Changing thermostat on ruud water heater
1) Copy following link to adjust water heater temperature.:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add a comment if more help is needed. Jan 2013
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 26, 2013 | Rheem Ruud Commercial Electric Water...
My Rheem water heater is giving a ECO failure, How can I fix this?
Question posted under Rheem water heater.
Model number and gas valve are unknown. Add a comment.
Following information applies to typical tank-type gas water heater, and does not apply to tankless water heaters, boilers, indirect heaters, solar water heaters, etc or for electric water heater.
Electric water heater ECO is located on upper thermostat.
Open top cover and ECO can be reset by pushing in red reset button,
Or ECO can be replaced by replacing thermostat. Add a comment.
Open following link to see typical tank-type gas water heater ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Change temperature setting
You posted under Rheem water heater but don't give type of heater or type of fuel.
Open following link for typical water heaters and many different kinds of thermostat controls:
For more detailed information, add a comment with information from the label on side of unit.
Label will say if water heater is tank-type or solar-assisted, tankless, and if water heater is gas or electric.
Product manual will also show thermostat information.
Add a comment and I might have link to your manual so each of us can read about product.
Manuals are critical tool for getting unit to work correctly over time, and important for homeowner showing needed maintenance and advisories for each model.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 30, 2011 | Rheem Water Heaters
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Basic info on Rheem
Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
This will restore water heater to full 99% efficiency.
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
If you want to test thermostats and all parts before replacing anything:
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
The water want stay hot very long
Age of Rheem
water heater is first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
D) Water heater has some hot water.
geno_3245_183.jpgRheem element
Dec 14, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I need to adjust water temperature, and dont have a manual. i have a 81v40d C model , 40 gal electric.
Here is a tip that I wrote to help people understand how to adjust the temperature on their electric hot water heater.
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Jul 18, 2010 | Rheem 81VP15S Point-of-Use Electric Water...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
71 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
