Question about GE Profile WPRE8100G
GE WPRE8100 washer starts to fill and immediately shuts off
When the washer starts to fill with water on any cycle, it sometimes puts in a small amount of water and then the machine shuts off. If you push the start button again, it will keep doing the same thing. After several tries, it finally starts and completes the wash cycle successfully. It then may work fine for a few washes and will then start the immediate stop when filling with water. It is getting worse.
    Top Expert:
  • GE Master
  • 85,222 Answers
I would suspect the washer control panel or timer is the problem.
Posted on Jul 25, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Posted on Jan 06, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Posted on Mar 21, 2009
Anonymous
SOURCE: GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Posted on Mar 27, 2009
tbirdfan1
Michael Thomas
  • 3051 Answers
SOURCE: ge washer wbse3120b2ww does not fill water and go to the final sp
hELLO THERE
well it is looking like you have a water controle solinoid valve that is malfunctioning and needs to be replaces i would contact your nearest dealer to see what the part is going to cost and have it replaced and if you have a warranty with the machine see if you can use it .
best of luckmike
Posted on Jul 31, 2009
jimorris77
  • 411 Answers
SOURCE: ge washer quits filling and spinning mid cycle
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer, a front load washer, or a dishwasher, I suggest you
go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as many other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you to a place that will help you solve the problem. Good luck with it.
Posted on Dec 07, 2009
Washer wont fill but work fine through all other cycles.
My washer will not fill with water to the level that I set it on the panel.
Dec 14, 2013 | GE WBSE2090A Top Load Washer
I have a GE Top Loading Washer. Model Number wcse4160b3ww. When I put it on any cycle it will not fill with water but insteads immediately starts to agitate. It will then go through the whole cycle...
most likely the water valve is faulty. The inlet water valve is at the end of the fill hoses. trace your way to it and get a new one and replace it. Before you do check the inlet filter is not blocked. good luck
Jan 26, 2011 | GE WBSE3120B Top Load Washer
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
It does fill to capacity on the rinse cycle only on large or super levels.
Jan 06, 2011 | GE WBSR3140DW Top Load Washer
Water runs but doesn't fill tub and wont spin if put on spin cycl
Jan 09, 2010 | GE WBSE2090A Top Load Washer
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
Washer continues to fill with water, no shut off. I turn the connection off at the back of the washer when I hear the change in the water pressure and the washer then goes through the cycle. Solenoid? This...
You have a float valve that works much the same way that the float in your toilet tank works, either your float is leaking, (full of water), or the valve actuated by the float is bad.
Sep 18, 2009 | GE Profile Prodigy WPSE4200A
GE WHDSR315 washer randomly drips still after done filling
you looking for a new water valve assembly...not very hard to replace..maybe a lil' messy
Aug 28, 2009 | Washing Machines
Machine is not filling with water.
hi
the solution is so simple, you have to open it
and clean the plastic pipe that runs from the tub to the load switch, sometimes gets dirty with detergentes and mud.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
GE Potscrubber Disshwasher GSD700G, wont cycle
Most washers do not fill they spray the dishes. When enough water has accumulated in the bottom a float switch shuts off the water and turns on the pump to remove the water. If the pump motor does not remove the water the cycle will not continue but the timer will. There may be something clogging the pump and resulting in an overload condition for the motor. This would account for the smell. A pump may turn freely when you spin it by hand because you cannot spin it fast enough by hand to determine if the pump is obstructed. Does the cycle drain the water? If the cycle stops and there is water in the bottom not being pumped out then you should look at the pump and the motor to determine problem.
Jan 19, 2008 | GE 24 in. GSD2230Z Built-in Dishwasher
GE Profile WPRE8100G Logo
158 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
