1996 Nissan Altima Logo
Anonymous Posted on Nov 13, 2012
Nissan Altima 96 doors wont stay locked.
When i lock the doors with the automatic lock button on driver door it unlocks automatically. if i try and lock any doors with the key i can not even turn it left. all the doors do this together and it happens everytime no pause. lock unlock. it will not stay locked.
  • Anonymous Nov 14, 2012
    today i locked the back doors and they will lock and stay locked unless i try to lock the front then everything unlocks....what could be the issue?
Anonymous
Level 2:
New Friend:
  • Expert 151 Answers
  • Posted on Nov 14, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
151
Questions
Helped
45662
Points
477
REPLACE YOUR DRIVER SIDE DOOR LOCK MOTOR BEFORE YOU REPLACE IT DISCONECT IT FROM ELECTRICAL CONECTOR TRY LOCKING CAR IF IT WORKS THEN REPLACE THE LOCKING MOTOR LET ME KNOW MABY I CAN HELP IF YOU NEED ME TWO OK
2 Related Answers
Anonymous
  • 162 Answers
  • Posted on Jul 31, 2009
SOURCE: 2003 Nissan Murano Driver door won't lock or unlock with keyfob
about 14 bux at this link
http://www.autopartswarehouse.com/search/?N=5716+776&Nr=AND(wpn_tl_name:Auto+Body+Parts+%26+Mirrors,wpn_scat_name:Door+Lock,wpn_cat_name:Doors+%26+Components)&refType=Brand&refValue=Replacement
Anonymous
  • 1111 Answers
  • Posted on Sep 21, 2009
SOURCE: My daughters Nissan Altima program keyless entry
could be someone on the same frequency as well ......not fully sure though
1helpful
Horn honks doors lock be self
does this help? look in owners manual for how to turn "on or off" the auto lock feature.
Automatic Door Lock/Unlock
The automatic door unlock function is a vehicle personalization feature with the following 3?programmable modes of operation:
1. All: All of the doors will automatically unlock. 2. Driver: The driver's door will automatically unlock. 3. None: The doors will need to be unlocked by a door switch command or by pressing the the lock button on the RKE transmitter. The All or Driver modes may also be programmed as to when the automatic door unlocking will occur.
1. Key Off: The door(s) will unlock when the key is turned off. 2. Shift to Park: The door(s) will unlock when the vehicle is shifted into P (Park). The delay lock function may be enabled or disabled. When the function has been disabled, the doors will only lock by a door switch command or by pressing the the lock button on the RKE transmitter. When enabled, the doors will not lock until five seconds after the last door is closed.
1helpful
1993 Nissan Altima The security light is blinking and the car wont turn over. it has a good battery. Is the flashing security light preventing the car from turning over?
Yes, the security system shuts power to the starter and fuel pump. You can try disarming by unlocking and locking the doors the power door locks switch (depends on model). Place the key in the ignition and set to ON, ALL doors closed!! Cycle the locks using the power locks button on the driver's door "lock" then "unlock" if this doesnt work, try same method with the ignition OFF. Otherwise your security system is malf.
I have a 2006 GMC Envoy Denali. The power locks on both the rear passenger side wont unlock automatically. i have to manually unlock it. although the automatic lock option works. All the other doors work...
both the rear passenger side wont unlock ???? How many doors are on the passenger side ? Or both back doors don't unlock ? Two relays lock / unlock the back door's Not the lift gate . The BCM controls the relay's . The relay's are located in the rear fuse box . Under back seat .
2helpful
4answers
2answers
Automatic Door Locks when you start driving
Yes, there is a way to reprogram your car to lock the doors when the gear selector is put into Drive.
Follow this site for a complete step by step re-program of the door locks:
http://www.nialtima.com/automatic_door_locks-113.html
2007 Altima automatic door locking
I consulted a Nissan master technician on this one, the Altima does not have auto locks, other owners have posted your same question as well and the experts answer is the Altima not equipped with this feature.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
