Question about Sony SNC-RZ30N Network Camera
Network connection does not light
The network light on the camera does not light when plugged into the modem
WVC210 CISCO PTZ camera... i can access through ethernet but can't access through wireless. I had tried installing in the sameway specified in the manual.
I had the same problem. Here was my successful solution:
reset the modem
only change the SSID (do not activate the security yet)
reset the camera
install the camera
set the static ip address
set the SSID to match the modem and save settings
unplug the power and the ethernet to the camera
plug in the power to the camera and wait for the lights on the front are illuminated
go back into the camera and set the security settings
go into the modem and set the security settings.
I hope this works.
Jul 07, 2011 | Cisco WVC210 Network Camera
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Need help to install router, westell modem already installed
Turn off the modem (unplug it). Plug the eithernet wire into the router and into the modem. Turn on the modem - when lights become stable, turn on the router. - when the lights become stable, turn on your wireless computer. Make sure your wireless is enabled. Use the wizard you will find in Networking (Control Panel).
I love Network Magic for network management, You may choose to get this program and use it. Google "Network Magic"
I hope you find this post informative.
Oct 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Modem removed and unavailable device com1
First of all uninstall and unpluged your modem then reinstall your modem without attach it. After installing you should attach it or plug it and if required during installation you should plug it during installation.
Now create connection and run it. It will work properly.
Good Luck
Aug 24, 2009 | HP COMPAQ MODEM 56K PCI (263371001)
OK I had the RCA DMC425 plugged into my laptopalright easy.I unpluggled eveything turned off the laptop so i can clean around my computer desk.When i finished i plugged everything back in and soonenough it...
troubleshooting a network is a multiple step process.
1. Establish that your modem is working properly, and plugged in. As per the diagram shown here:
  • Your "Cable link" light should be on (signifying that the outside cable is properly connected to the router)
  • Your "Internet" light should be on (signifying you have an established Internet connection)
  • And, most importantly, your "PC Link" light should be on (showing that at least as far as the modem is concerned, it is detecting that the computer is plugged in to it.
2. double check to make sure that the network cables are seated properly, and plugged in all the way. the PC link light should give you an indication for modem-side- the LED light around the network cable jack on the laptop should give you an indication PC-side.
3. check on your laptop for any security software that may restrict new networks from being detected and disable them to test. For example, Symantec or Mcaffee Firewall can sometimes block a "new" network from being detected.
4. Completely shut down the laptop and unplug the power cord from the modem. Plug the modem back in. Wait around 3 minutes for the modem to initialize and do it's thing- then turn on your laptop and see if this resolved your issue.
If this doesn't work, you may want to try other things, such as resetting your network, and removing/re-installing your network adapter drivers.
Aug 03, 2009 | Acer Computers & Internet
My Belkin 802.11g Wireless Desktop Network Card keeps dropping its connection. This happens every minute or so at present. Signal strenght to BT Home hub is strong (four bars) and drivers are up to date....
Sounds like you need to re-sync your modem and router. Remove the power plug from the modem and router. Then first plug the modem power on and wait for all the lights to come on. Then plug the power to the router and wait for all the lights to come on. Re-start your PC and see if it is ok. Good Luck.
Jul 29, 2009 | Belkin 802.11g Wireless Desktop Network...
When i try to connect 2 the internet it says somthing about a network security key or phassphrase
Do you have a Wireless Internet Network. If you do, then go to your modem, and disconnect the power wire and plug out your Wireless Internet Network. Wait for about 10 seconds, then start reconnecting your internet modem and plug in your Wireless Internet Network. Sometimes all 4 green lights will appear.
If it said "network security key" or "passphrase". Then you should buy a USB Flash Drive.
Jul 15, 2008 | Acer Computers & Internet
Network adapter is working but still not getting good connection
Make sure the light on your cable modem that represents your connection to the computer (it might be marked LAN, Ethernet, or PC) is lit up and isn't flashing. The light will tell you if your network card is properly connected to the cable modem.
If the light isn't on, make sure you've connected the wire to the right port on the cable modem, and try restarting the cable modem by unplugging it, wait 30 seconds, and plug it back in.
If it still doesn't work after that, contact your Internet provider. Their technical support department can help you get it set up.
Dec 06, 2007 | HP Broadcom NetXtreme Network Adapter
Sony SNC-RZ30N Network Camera Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
