Ovens Logo
Question about Ovens
Frigidaire convection oven - have no instructions, can't get it started -help please
Can't clean it
Posted by Charlotte Philp on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hello Charlotte Philp - I understand you want to instructions on how to operate/clean your unit. May you please provide me the model number so I can further assist you better in pinpointing you the information or you may visit the Frigidaire website that I found.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
I will recommend taking off the last letter of the model number so you can pull up the information.
Posted on Nov 14, 2012
5 Related Answers
Anonymous
SOURCE: frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
Posted on Feb 01, 2009
Anonymous
SOURCE: Elitech 1300W convection oven: How to set it for self cleaning
Hi
If you watch the advert for the Nuwave or Flavorwave they set the machine to defrost setting.
Put water in and a bit of washing up liquid and put on for about 10 min.
Posted on Dec 09, 2008
Anonymous
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
Anonymous
  • 3361 Answers
SOURCE: My KitchenAid Supra self cleaning convection wall
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Posted on Feb 28, 2009
Anonymous
  • 291 Answers
SOURCE: Frigidaire Oven making vibration noise when
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Posted on Dec 11, 2009
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
‎How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
I misplaced my manual and need to have instructions to use the self-cleaning feature.
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
How to repair the control panel when the convection oven does not work but other things work
Good Morning Friend,
I understand you want to know how to repair the control panel on your Frigidaire range. I see that the convection oven is not working, however other functions are working. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the convection oven is not working. Hope this is helpful.
-Best Regards-
WP
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
I have a frigidaire Electrolux self cleaning convection oven. I put it on self clean and it went fo over ten hours. now the door is locked and I cant open it. I tried to self clean and it wont start. The...
These ovens have notoriously bad control panel electronics. There is one control board for the oven that can be replaced or sent out for repair, $100 to $300.
Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
2answers
Fridgidaire Wall Oven will not heat
1) If there is a reset on the electronic panel try that.
2) Set the temperature to 200 and see if works then.
3) Put a baking tin in the oven with a piece of meat in it.
4) Uninstall the Wall Oven and take the back off and check the wiring for the elements and the convection fan.
Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
TURNED THE OVEN TO "CLEAN" LAST NIGHT AND NOW THEY ARE FROZEN.... CANNOT GET THE DOORS TO OPEN AND THE DIALS ARE FROZEN AS IF THE OVEN THIKS IT IS IN CLEANING MODE... WE CANNOT FIND THE...
set the range as if you are setting it to clean and after you hear it cycle into clean then cancel and it should unlock ,,,, please remember to click on rating / thanks
Top Ovens Experts
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
