Canon XH A1 Mini DV Digital Camcorder Logo
scott Posted on Nov 12, 2012
Can't change playback Std to HDV
Have two Canon XH-A1's and one is recording and playing/uploading just fine. The other records fine, but won't upload to Final Cut (won't even be recognized). When I go into Signal Setup, the Playback Std is showing "....", but it is greyed out so i can't change it there. What setting do I need to change so that the "Playback Std" = "HDV"?
Carlos Pompa
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 20, 2021
Carlos Pompa
Contributor
Level 1:
Answers
Questions
0
Helped
226
Points
Mine was grayed out and for the life of me I couldn't get it to work UNTIL... I tried removinf the firewire cable I had connected to the camera. That solved the whole issue for me. Hope this helps.
3 Related Answers
Anonymous
  • 37 Answers
  • Posted on Nov 06, 2008
SOURCE: Playback STD Locked Playback is Restricted message
the tape most likely has the lock switched on, it's secured so no one can even view it, why it happend, beats me, look at the bottom of the tape, if it has the lock switch, and is pushed up to "lock" push it back down, if  that doesn't work than I'm not sure, sorry.
hope this helped- snowsurfer58
Anonymous
  • Posted on Dec 20, 2008
SOURCE: My Canon XH A1 will not turn on to record
Check your little lock and standby lever at the back of your hand strap, its likely positioned between standby and lock.
Anonymous
  • 15 Answers
  • Posted on Jan 14, 2009
SOURCE: Getting poor quality uploads to my pc from my Canon XH-A1
You need to upgrade you ingest system. Windows Media Player(and your system card) probably can't handle the load. Try "Scenalyzer" it's economical, versatile and stable( http://scenalyzer.com/).
2answers
How can I transfer my recordings
Hi Greg, you need to provide more information, for instance , from what medium to what medium, (media types.) Please add the detail and resubmit
My XHA1s records but won't play back any tapes unless you're in ff or rw. One of the tapes I had just loaded part of on my computer a few days ago with no issues. As far as I know no settings have been...
Sounds like the edge of the tape has been damaged. The edge of the tape has the speed encoded so the playback will know what speed to play the tape. Look at the edge of the tape for wrinkles. If present, throw away the tape so you won't use it for an important recording.
3helpful
While trying to upload video i get std playback is locked
According to page 89 of the manual (available here), you need to set the playback standard (HDV/DV) of the camcorder to match the standard used when recording the tape. Instructions for doing this are on page 40 of the manual.
1helpful
2answers
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
42helpful
3answers
My Canon XH A1 will not turn on to record but the camera will turn on to watch playback. I need help!!!
3answers
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
