Question about Ultra Linear UL-4400D Car Audio Amplifier
Wire for three speakers ultra linear 720w
Three channel
2 Related Answers
Anonymous
  • 631 Answers
SOURCE: ultra linear ul-600hc
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Let me know if you have any other questions.
Posted on Aug 26, 2008
Professor_V
Professor_V
  • 93 Answers
SOURCE: Hello. I have an Ultra Linear Amp - UL724 model. I
YOUR METHOD OF TROUBLESHOOTING USING THE PROCESS OF ELIMINATION IS RIGHT ON AND PERFECT. IT INDICATES A BAD AMPLIFIER CHANNEL. I KNOW THIS SOUNDS ODD, AS YOU HAVE TWO OF THESE NOW. IT IS RARE, BUT I HAVE SEEN INPUT CONFIGURATION SWITCHES WIRED BACKWARDS, SO THE ONLY THING LEFT TO DO IS TO HOOK UP THE BAD CHANNEL TO ONE SPEAKER ONLY, BY ITSELF. THEN TAKE ONE RCA ONLY AND PLUG IT INTO ONE RCA INPUT AT A TIME. THEN MOVE THE INPUT SWITCHES AND REPEAT THIS PROCEDURE UNTIL YOU HAVE TRIED ALL SWITCH COMBINATIONS AND ALL INPUT JACKS. WHAT YOU ARE TRYING TO DO AT THIS POINT IS TO DETERMINE IF THERE IS ANY RCA JACK WITH ANY SWITCH POSITION, THAT WILL ALLOW YOU TO GET OUTPUT FROM THAT CHANNEL. IF AFTER THIS TEST, YOU STILL HAVE NO OUTPUT, THEN NO MATTER HOW ODD, IT WOULD INDICATE THAT YOU DO IN FACT HAVE A SECOND DEFECTIVE AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
How do you hook up the dynamic linear drive on a kenwood basic m1 power amp to the speakers?
dynamic linear drive refer to the amplifier circuit. How ouput stage a driven.
How to connect speaker refer to sigma drive. its fairly simple, you start whit (for one channel) 4 wires and finish whit 2 at the speaker. (you joint positive together and negative together).
Normaly the feedback loop a closed inside amplifier circuit. Sigma drive give you the possibility to close it at the speaker connector. Doing like this give a better performance from differential amplifier by skipping speaker wire resistance.
May 29, 2012 | Kenwood Audio Players & Recorders
Hello. I have an Ultra Linear Amp - UL724 model. I am wiring it up to play in 2 channel mode - in stereo. I can only get one channel to work - the left... I swap the rca cords, still only the left side...
Nov 07, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
My pioneer gm-7300 amp is getting hot and shutting down
is your amp mounted in a place where there is little space around it? it needs to be able to circulate air properly, so make sure theres nothing covering it up. also, make sure you are speakers are wired to at least a 4 ohm load. if its any lower, it will build up too much heat. let me know what kind of speakers you have connected and how many, and ill tell you how to get it to the proper ohm load.
Aug 08, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Hi all i have a Denon DRA 455 with Eltax Linear 6.5 wich is 8ohms i have a sub but no sub output, apart from sharing power between them, how can i hook these up please? thanks
You did not state if your sub is a powered sub or not, but if you use the "B" channel for your sub, it should work. This is possible if the denon will work with "A" channel and 'B" channel on together. The back of the Denon should have two sets of speaker outputs. Connect the "B" channel speaker outputs to the sub. The "A" channel will still drive your 6.5's.
Aug 05, 2009 | Audio Players & Recorders
Extreme distortion/static in music.
you might have blown your speakers. Thats what it sounds like, if it got loud with a lot of low-end then it got all staticy and distorted, you fried teh speakers.
May 27, 2009 | Phase Linear PLC 400
How to hook up linear ul4400d to my two alpine 10" subs. Running pre amp out of deck . only driving subs
if they ar dual voice coil wiring them ing the box parralle and play your wm in bridge mode
Apr 10, 2009 | Ultra Linear UL-4400D Car Audio Amplifier
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Ultra linear ul-600hc
Aug 26, 2008 | Ultra Linear UL-600HC Car Audio Amplifier
I have problem with my mono amplifier
Amplifiers have thermal protection. They will typically shut down at ~180F. If your amp is shutting down after running it hard for 20-30 minutes, you may not have the correct load impedance (speakers wired incorrectly).
If it overheats as soon as it's switched on (no audio), the amp may be in need of repair.
Jun 21, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Ultra Linear UL-4400D Car Audio Amplifier Logo
46 people viewed this question
Top Ultra Linear Car Audio & Video Experts
Marvin
Marvin
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
