if everything was correctly installed then yes, but depending on what was used, the installer may have opted for a custom configuration. however, the fader and balance really should work.
make sure that you have a good ground, make sure you have the right amp turn on wire, and your power wire is fused, best solution is to have it professionally installed! Amp install is very basic if you are having a hard time with that, I wouldn't attempt to try it or have one of your buddies install it! FRIENDS DONT LET FRIENDS INSTALL!
Generally, if you are using the manufactures fuse rating you can use a slightly higher rating and it will resolve the blowing fuses. Fuses supply resistance, if there isn't enough resistance you'll fry the system board in the amplifier. But if you have 25 amp fuses installed, install 30 amp, if you have 30 install 35 amp, 35 install 40. Anything higher will damage the amp.
Hope this helps.
A rare chance, something may be internally wrong with the amp and shorting it out which will blow the fuse.
Use the incorrect wiring of subs to the amp, you'll blow fuses and damage the amp from it turning off consistently. The amp should be running at 2 ohm stereo stable or 4 ohm mono stable.
Very few amps are designed to run at 1 ohm or less. Not to mention the subs can't handle it.
Power amps must be connected + battery wire to the amp +b terminal with a gauge 8 or bigger depending on the power rating, - ground to the car chassis as short as possible,connect cords from head unit to power amp with good groundings, and remember to connect the speakers and the remote trigger from head unit to turn the amp on.
schematic & instructions on deck
red (+) - power - 2 amp's power inlet power (+)
black (-) - ground - 2 amp's power inlet ground (-)
deck yellow wire - remote - 2 the remote amp
deck outputs 2 the RCA amp inputs
amp RCA outputs 2 speakers
it is wise that a pro will install the system
it will give u less concerns and u will have warranty on the installation
this will save u the money u will spend for fixing a bad installation
