I am unable to hear out of my left headphone unless i set the volume control to a certain point and i have to press down (on the volume control wheel) for it to come out with sound. I have a tdk lor st-600
SOURCE: No sound coming out of the left speaker
It sounds like you have a break in your cord right where it joins the plug. You will either have to replace the plug or buy new headphones.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
hope this helps
