I have a similar problem with my 406 radio/cd player. What worked for me is to push another cd about halfway into the slot and under the stuck cd, press eject and lift slightly. It took a couple of times but did finally eject. Problem with mine is when I put a new cd in it gets stuck again.
SOURCE: cd jammed in player
MY DAUGHTER PUT A CD IN THE CD PAYER AND NOW MY CD PLAYER DOES NOT WORK.I HAVE A 2005 NISSAN ALTIMA.THE KIND OF RADIO IS A BOSE 6 CD CHANGER.I PRESS THE CD BUTTON AND IT SAYS PUSH EJECT.I PUSH EJECT AND IT SOUND LIKE IT'S TRYING TO EJECT BUT NOTHING COMES OUT.CAN YOU HLP ME
for sure button for FM is out of order
i was wondering if you were able to find a solution for this. I am currently having this same problem with my vehicle (as a few others as well). if you could please let me know, id greatly appreciate it. my email is [email protected].
SOURCE: Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
SOURCE: Cd's are stuck in cd player and will not eject,
i have a 2005 kia Amanti. i believe a cd is stuck and the cd palyer will not rptate or eject. does anybody have a solution?
By saying CD won't work are you talking about CD player can't read CD?
no. the player will not respond. the led does not show anything. the cd is stuck inside. does the cd player run on a separate fuse?
