You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
SOURCE: How to restore ALL factory settings to the Nokia 2630
my Nokia 2630 Serial Number 354861022927732
I do not restore due I have not known his code
please tell me the code
SOURCE: i have to restore factory setting in nokia 1110i
Turn of your phone for 30 Minutes and Then Try 12345 not 1234. Please Vote if solved.
SOURCE: Nokia 6030 Security code required???
i have a nokia 6030 phone and whenever iam trying to restore my factory settings by the default code 12345 its not working properly
