I had a Nokia before this phone and I could print of the texts I need to but with this Sony Ericsson Xperia Neo I have tried everything I can think off to print these texts and can't do it. I am only able to use a usb cable because my printer is not a wifi one. Is there any once that can help me please. Thanks x
You can use Coolmuster Android Assistant to transfer your text messages to computer, then you can open the transferred file to view your messages. How to Copy Text Messages from Sony Ericsson Xperia to Computer
The following guide will teach you how to print out text messages from Sony Ericsson Xperia in 3 simple steps. If you're interested in this topic, please read this page for details.
How to Print Text Messages from Sony Xperia
Here is a guide may help you:
http://www.android-recovery.net/print-messages-from-samsung.html
People always like to attach an external memory card to extend its storage space. Thus, if you think all your text messages is stored on these external memory cards, then you're totally wrong. In fact, only the multi-media files are saved in the external SD card and the text messages are stored in the internal storage. So sometimes you have to delete some precious or important SMS messages to free up more storage space to get new data.That is the reason why it is hard to print out Android phone text messages on computer.
Here is the solution: How to Print Text Message from Sony Ericsson Xperia?
To print your text messages, you could download an app called "Email My Texts SMS". You email the texts to yourself, you can save the email or print it. It is easy to use and highly rated.
SOURCE: How to set MP3 as text message tone on Sony
If you want to set an mp3 or "Custom" tone for your "Notifications" you can dowload an app or...
Connect your X10 to your computer. Pull down the usb notification in top left of screen and mount sd card.
Then go into your phone menu via "My Computer" and either go into media/audio/notifications or create the folders yourself. Remember they must be lower case letters.
Then all you have to do is copy your tone into the "notifications" folder disconnect your phone from your pc and go into "Settings" "Sound and Display" "Notification ringtone" and it should now be in your list with the preset standard tones.
SOURCE: hi i just purchased a
hi there i just had the same problem but have since found the setting for it
Go into settings
select sony ericsson application settings
Select messaging
make sure notifications is selected
and choose a notification tone
ta da your phone should now alert you to any messages you recieve
SOURCE: how can i pass a song via bluetooth to another
1.select a song
2.go to option
3.there you can see the send option
4.select the sending option(bluetooth)
5.the bluetooth will search for available bluetooth connection
6.select the bluetooth connectivity which you have to send
SOURCE: hello, i have sony ericsson
Watch the following video on the instructions how to unlock your phone:
http://www.youtube.com/watch?v=dec8fUlJkac&feature=player_embedded
If the solution works for you, please rate.
Thank you
SOURCE: Toi can tim code Unlocked Sony Ericsson Xperia X10 Mini E10i
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlocking.com which is doing good service .....you can approach this website.
First, try this:
If that doesn't work, or if your phone is frozen:
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
The password is user defined, try the second method if you did not set a password.
Good Luck!
