If all the indicator lights are flashing after you've initialized your machine, reset it by turning it off and then on. If there's no disk in the brewing mechanism, all the indicator lights will flash.Sep 5, 2020
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it · Bosch Tassimo... ' Posted on Aug 23, 2014 ' Be the ...
Bosch TASSIMO red light water full Unsolved Problems - Fixya
0 Answers. Water sat in the bottom tray of my tassimo t65 and now it has two red lights flashing can I fix it. Aug 23, 2014 ' Coffee Makers & Espresso Machines.
Several possibilities:
(1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
