My v motion system doesn't turn on. My daughter played with it once and we put it away for like 11 mon now it won't turn on . Can anybody help me please ? Thanks
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
Tips & Warnings
Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
I would call EA and tell them your code does not work. I would also edit your question so that someone doesn't take your unique code and it it for themselves.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage). If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
sir i think it'll be nice if u remove the new graphics card from the PCI slot ...
then it''ll play in the normal default graphics
now u uninstall the software driver of ur graphic card then insert back it again and once again install the software with care... all will be fine ... there is no problem with the monitor sir ...:)
Doesn't want to accellarate while driving. In neutral it will rev up to a certain point but not full throtle. I put factory recommended uridium plugs (6) in, didn't help. Is it a catalitic converter problem or something else? thanks
