Question about Samsung ML 2010 Laser Printer
Samsung ML 2010 On line error red blinking, toner saver green blinkig
On line error red blinking, toner saver green blinking new toner, not use for a year in storage
Posted by Roberto on
3 Related Answers
SOURCE: red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Posted on Aug 18, 2009
SOURCE: Samsung ML-1710p - error
It is problem your fussier unite may be thermostat or or lamp is fuse.If you are not a technician you go to a service center.Or you are a technician open it and clean thermostat and heater lamp check by ammo miter.
Posted on Nov 27, 2009
SOURCE: Samsung ML-1710p - when attempt to print, leds
May be rejected this toner unite or paper could not feed properly.Service thoroughly your printer and Fuser unite.
Posted on Jan 07, 2010
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
I own a ML-2525/XAA and have a blinking light on the right hand side of the unit. It looks like: <--->/(a triangle with an explanation mark inside it.
Per your user manual, here is a list of all the LED status':
Jam (b-error.png)
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error (b-online.png)
Off
  • The machine is off-line.
Green
On
  • The machine is in power saver mode.
  • The machine is on-line and can receive data from the computer.
Blinking
  • When the LED slowly bilnks, the machine is receiving data from the computer.
  • When the LED rapidly blinks, the machine is printing data.
Red
On
  • The cover is opened. Close the cover.
  • There is no paper in the tray. Load paper in the tray.
  • The machine has stopped due to a major error.
  • Your system has some problems. If this problem occurs, contact your service representative.
  • A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
  • A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
  • Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
Samsung ML-1710p - when attempt to print, leds start slowly blinking simultaneously, "on line / error" - red, "toner save" - green
Nov 27, 2009 | Samsung ML 1710 Laser Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
I have a ML-2510, I turned it on and both the red light and green light flash constantly. Will not feed or print.
The green light blinking means that it is accepting or printing data.
But, the red light is for the error messages. This blinking means there is a toner problem. 1. remove toner cartridge from printer and gently shake to redistribute any that is left, or
2. You simply have to replace the toner cartridge with a new one - this one has been exhausted.
Jul 09, 2009 | Samsung ML-2510 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Samsung ML 2010 Laser Printer Logo
87 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
