The hussmann freezer is a 3 door model. it has one broken handle.
SOURCE: Fridge Freezer door replacement
You will need to order part number 059129. It will be in Europe/Germany phone +43-140447-200 for customer svc, +43-140447-300 for parts. Don't know if there is a US distribution office.
SOURCE: REPLACEMENT PARTS
heres the address and phone numbers to contact them
5 Cherry Blossom Rd. Unit 3
Cambridge ON, N3H 4R7
Phone: 519-653-9980
Fax: 519-653-1805
Toll Free: 1-866-764-0468
probably tech support could help you to find a parts distributor.
SOURCE: Defrost tube needs replacing
12999 St. Charles Rock Road
Bridgeton, MO,
63044-2483
USA
Phone: 314.291.2000
FAX: 314.298.4756
SOURCE: I have a hussmann commercial freezer model GGSM-3
The freezer is low on freon... it is cutting in and out on low pressure. It does not for the first ten minutes because the temperatures are higher when it is warmer... then as the temps come down the pressures drop and the vicious cycle begins....
Double check the type freon that is in there before adding so you do not mix refrigerants...there are a few possibilities...depending on the age of the unit.
This is not a DIY project, make sure to have a licensed pro do this for you!!
heatman101
