The the port doesn't have the "pins". What cable do I use to connect the imac to my HP LP2465 monitor?
SOURCE: IMac internet connection problem
go to a download speed test site & test what your ISP is giving you. I prefer www.toast.net they have great, free performance tests, both up & down, with a nice set of options. you can compare companies & email the results to your ISP you might want to review all the network & firewall pref's as well... Good luck... Ian
SOURCE: Internet connection failed
please check the ip configuration using system preferences in network option if its set to automatic or manual if automatic check the cable betwin your system and the network hub switch or wall socket is fine try also using another cable ...
if the status in your left hand side shows green that means cable is fine if have and ip address and is set to manual please check with your network administrator or it guys to check for proper ip address and gateway address..
there is like very rare chance for the network card in the system to go faulty afyter its mac
thanks and regards
thanksan nd
mos
SOURCE: Trying to get an HP 1401 printer to work on an
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11543&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=1103491&key=null&site=null
SOURCE: I have a Imac G5 17 Inch and the motherboard works
It could be the inverter or the circuit board on the screen itself. One of these, or possibly a bad video card.
I can only comment generically:
I would try to uninstall the drive on the OS. Then re-start the computer. After the re-start, connect the drive and see if the drive re-installs itself.
If the error persists, then the drive is indicating failure. To absolutely verify if it has failed, take the drive to a store where there are MAC computers and try the drive on one of their computers to see if it works.
A continuous flashing LED on most devices where the LED does not normally continuously flash is an indication of a failure of the device. Some devices will flash an error code when designed to do so, and if possible.
Jerry G.
Testimonial: "thanks. its a device failure. I had connected it through keyboard usb port, and it seems that the power was not flowing properly to run external memory. "
