Kitchen Ranges Logo
Dave Kirkpatrick Posted on Nov 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kitchen Aid Superba Electric Range that is about 5 yrs old and the digital display has stopped working. all the oven features work but not the display. Is it a board problem or is it possibly an easier, less expensive fix?
Richard Roth
Level 3:
Top Expert:
  • Kitchen Ranges Master 9,472 Answers
  • Posted on Nov 11, 2012
Richard Roth
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2627338
Points
28464
What is the model number of the unit?
3 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Apr 03, 2008
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
fixyourboard
Fix Your Board
  • 310 Answers
  • Posted on Oct 13, 2009
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
Anonymous
  • 635 Answers
  • Posted on Mar 05, 2010
SOURCE: Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
My GE Oven Px7 is about 12-15 yrs old and when we last used it the beep was continual and we pressed the button for it to stop and the digital screen went blank. We now get no beeps or anything on the...
I inherited a px7 electric microwave stacked oven, and on days like today I want nothing more than to just get rid of it! How do I use the self cleaning feature? The instructions seem simple enough but I just cannot get it to work.
PUT THE OVEN ON SELF CLEAN AND IT DIED
the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
Oven quit working burners and digital display work fine
Check to see if the coils are properly connected. If so, you may need to replace the thermostat unit, which monitors the actual oven temperature. Hope this helps.
11helpful
2answers
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
Self cleaning does not work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Kitchen aid superba electric convection range
Looking for a part KitchenAid DBL Convetion oven (12 years old)
Are you talking about the oven pan at the bottom of the oven? If so, the part number may be 1059318 and costs about $50. You can find parts for your range at repairclinic.com. Just type in your model number in the search window. There is an extensive pictorial part index with price infomration. Unfortunately, this part did not have a photo with it.
Kitchen aid slide in range - oven stopped working
Wynco, first thing I'd check is whether or not you are getting the 220 volts the unit needs. Find the circuit breaker and turn it off and then back on. This should be a dual or linked breaker. The breakers do corrode and wear out and may need to be replaced.
Top Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
