I have cleared all settings. I have increased the ISO. I've taken the batteries out and put them back in. Turned camera off and on.
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Error message...Press shutter release button again.
Perhaps the memory card is corrupt. Try using another memory card, and always formatting them in the camera before use. (note this erases all pictures from the card.)
If this doesn't work, try using the camera's reset function. I believe this is done by holding down two particular buttons, which may be marked with green dots. If not, check the manual.
Also try taking out the battery, waiting 5 mins and replacing it.
If the lens has an aperture ring, make sure it is set to the smallest aperture (biggest number).
Try a different lens to see if it's the camera or lens.
Otherwise I fear it may be a repair job. :(
SOURCE: Error! Press shutter release button again
I found the fix for this Nikon Shutter problem and posted it on my blog.
http://jacko0.wordpress.com/2009/10/13/d40x-underside/
SOURCE: Turning on the camera, next to the battery display
Need the replace of sq base plate unit. Send to Nikon service.
Testimonial: "I tried everything! As you suggested I'll take my camera to the Nikon Service Center. Thank you! "
