Turning the camera on and the shutter for the lens won't go down.
SOURCE: Canon 17-85 Lens with Rebel XTI Camera
This is because the camera will not expose a picture until the auto focus is locked. If you are shooting in dimly lit conditions, the AF might have a hard time obtaining a lock. Using the flash as auto focus assistance many time helps in this condition.
Another reason might be that you try to focus on even surfaces with low contrast. The auto focus work by sensing contrast. Even surfaces, such as a white wall or the sky, have very little contrast, therefore the auto focus will not be able to obtain a lock.
The solution here is to point the AF sensor at something with more contrast, such as an eye, a pole, or basicly anything that have edges/lines.
I hope this help you!
/Chris
SOURCE: My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
SOURCE: its shutter is not opening
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
SOURCE: Canon IXUS 100IS - 'Lens error, restart camera' message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
SOURCE: Canon SX100 camera The lens shutter keeps sticking
Sounds like your lens is not retracting due to the fact that the internal alignment is off. You might have bumped the camera with an open lens and not the sliders are out of alignment. there are very fragile pieces in there that keep the lens aligned, when they are off, the lens keeps acting up. this company will give you an online quote immediately to fix it http://www.teleplancamerarepair.com/Canon_Powershot_SX100_IS
repair includes camera cleaning
