Question about RCA VR637HF VHS VCR
I have VCR aiwa FX4300. This is permanent SAFE, can not play
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Probably not then, but you could try a tape recorded at EP.
Jan 05, 2013 | Aiwa HV-MX1 VHS VCR
Need instruction manual for Aiwa RC-AVR03
RC-AVR03is model number of remote control of Aiwa VCR and is does not have any separate instruction manual, post your Aiwa VCR model number (would be written at rear of VCR) to provide you instruction manual copy.
Thanks.
Nov 13, 2010 | Aiwa Televison & Video
AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Jan 15, 2009 | Aiwa HV-MX1 VHS VCR
Lost manual
how do i unlock the pin code? aiwa fx7500k
Oct 01, 2008 | Aiwa HV-FX7000 VHS VCR
NO VCR MANUAL
I have no solution, but have the same problem: NO Manual for my /hv-BR 5000 BH VCR. Can anybody help?
Sep 21, 2008 | Aiwa Televison & Video
Aiwa GX1100 VCR
When safe show on the screen, it actually means that the child lock feature is on.
All you have to do is press the child lock button again on the remote and it should flash "OFF" on the screen.
Hope you have the remote :)
Sep 13, 2008 | Aiwa Televison & Video
Picture gets bad after playing a while
Just the usual problem of needing the rubber belts replaced.
They last about 6 years normally so you are overdue.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Jan 14, 2008 | Aiwa HV-MX1 VHS VCR
Aiwa mx100 (al system vcr)
if your vcr is a multisystem, select the proper system in your vcr for the video to be played. but if not, you cannot play your PAL in your NTSC vcr. good luck!
Feb 25, 2007 | Aiwa HV-MX100 VHS VCR
Our Aiwa MX100 doesn't play our pal system tapes
Just Clean the Video heads with a Wet Type Head Cleaner. Do 2 or 3 runs. Should clear up the problem.
RCA VR637HF VHS VCR Logo
77 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
