Question about Philips Televison & Video
Wrong region DVD player won't play a disc
My phillips DVD player won't play a certain disc wrong region how do change region. I have no remote controller with the unit
Posted by betty_desmon on
  • rtxwsauogv
    rtxwsauogv Jul 26, 2021
    My ex-wife makes $250 /hour on the laptop.She has been fired for seven months but last month her pay check was $17147 just working on the laptop for a few hours.
    Read more here>>>HERE www.Pays99.cOm
  • Anonymous Sep 06, 2021
    Betty why is here.
    https://en.wikipedia.org/wiki/DVD-Video#...
    exact cures are buy a DVD drive that is region free
    cure 2, buy drive that can be switched, there is list of drives that can be here
    https://www.videohelp.com/dvdhacks?dvdpl...
    keep in mind drives made from 1996 to now , can or can not be set region free, , one must get the model of your drive first. and look it up here.
August Brown
    Master:
  • Philips Master
  • 471 Answers
Region locked DVD can only be read or recognized by the corresponding region DVD player. You need to make clear that what region code your DVD is. Check below table to find out:
  • Region 1 - United States, U.S. Territories, Canada, Bermuda
  • Region 2 - Europe, Japan, South-Africa, Middle-East, Egypt
  • Region 3 - SE-Asia, East-Asia, Hong Kong
  • Region 4 - Australia & NZ, South-America, Caribbean, Pacific
  • Region 5 - Eastern-Europe, Russia, Central- & South Asia, India, Africa
  • Region 6 - China
And you can use some methods below to play a region-locked DVD:
  • Method 1: Use the corresponding DVD player or a region-free DVD player
  • Method 2: Use region-free DVD player software
  • Method 3: Use DVD copy software to copy region-locked DVD to region-free DVD
  • Method 4: Use DVD ripper software to decrypt the region-code
Source: How to Play Region-Locked Blu-ray/DVD on PC?
Posted on Jul 22, 2021
Nanny
    Genius:
  • Philips Master
  • 2,351 Answers
If you do have a DVD player locked to a specific region and a bunch of DVDs with different region codes on them, you can make a region-free DVD copy of your region-locked DVD discs. Then the region-free DVD copy can be played on any DVD player. You can try Leawo DVD Copy, which is able to perform 1:1 lossless DVD copying, it can also help you compress DVD-9 to DVD-5 if you need.
Posted on Jul 06, 2019
Rob getz
    Master:
  • 689 Answers
Can,t be done with the one you have,
Posted on Nov 11, 2012
5 Related Answers
Anonymous
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
Natalie Ginter
  • 33 Answers
SOURCE: Unable to play DVD - incorrect region code or disc type?
Is it the Panasonic Portable DVD player
Posted on Nov 13, 2008
Anonymous
  • 189 Answers
SOURCE: what does wrong region mean?
HELLO
This occurs when you try to play a DVD from another country. It means that your player is not set up to read discs from that country. Look on the back of your player and it will tell you which region it is set up for (it will be a globe with a number on it).
Depending on what machine you have it may be possible to "hack" the machine via the remote control and set it to play all discs from all regions (to multi-region) it. Have a look on the web as there are many websites out there that will give you the info you need to hack the machine.
BE ADVISED! Not all machines can be hacked from the remote.
GOOD LUCK TO YOU!
Posted on Jul 21, 2009
Anonymous
  • 27 Answers
SOURCE: DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Posted on Jan 01, 2010
Anonymous
SOURCE: unlock telefunken tel9800 dvd/vcr combo region
open tray
enter 0520, then press up, down, left, right (these are the keys around the ok/enter button)
a message will appear on the screen showing current region
press 0 and enter
it should now play any region
hope this helps
Angel
Posted on Jul 04, 2010
What does the message Wrong Regional Disc mean
Almost all commercial DVDs that are sold have region code, which only allows the DVD to be played on DVD players that have this region code, and the only DVD players that typically do have this region code are those sold in that same region.
You can use a region free DVD player program to play your region-locked DVD discs on your computer. You can try Leawo Blu-ray Player. Leawo Blu-ray Player is the very program you can use to bypass the DVD region code of a disc.
3answers
Can't play dvd--wrong region
Commercial DVDs are released with region codes that restricts in which part of the world they can be played. Consumer DVD players sold in those regions are pre-configured with the correct region code for the given sales area. The United States, Canada, Bermuda, and U.S. territories are region 1. Europe (except Russia, Ukraine, and Belarus), The Middle East, Egypt, Japan, South Africa, Swaziland, Lesotho, Greenland and region 2.
sources:
http://forums.techguy.org/miscellaneous-tech/972005-dvd-wont-play.html
1helpful
2answers
Message "wrong Region" appears in my Sony DVD -
DVD region is an anti-piracy method to block DVDs from other countrys to be played on a region where that DVD isn't available for selling. You still can watch that DVD by changing the DVD Player region code from options but be aware that you have a limited number of changes, after changes reach 0 you cannot change DVD region code anymore and your DVD player will be stucked to a certain region that you selected.
Wrong region
Change your region to multi-region so it can play discs from any region but please check the instruction manual to ensure that changing the region does not void the manufacturers warranty.
Turn the DVD player on, and press "open" on the remote control or on the machine itself.
Press this code into the remote: 789
Press OK, then press 0. A "0" should appear in the lower left side of the screen. For Phillips, zero is the code number for multi-region. In place of the zero, you can also press the number of the specific region you want to play.
Play the disc to check if it works.
2answers
The player says wrong region code with every dvd i have!! help please Phillips 3020K
Where did u bought this DVD player?US,Canada,and Mexico?The DVD disc. used NTSC region format.Asia,Europe,Africa,and the Middle East.The DVD disc. used PAL region format.They can't be mix or it will not play as u find out.If u move in and out to another region of the world.U must have a regions free DVD player to play either NTSC or PAL regions.
4helpful
2answers
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Sony dvd wont play certain discs
yes the sony dvd players is made for certain regions it wont play other discs that are not either region one or two new zealand i think is region 3
1helpful
Why does the set not play certain discs (wrong region code)?
You need to check the dvd player manual for region restriction, for region restriction dvd's you cannot play on your dvd player so check the region supported dvd's whcih you can play on your dvd player.
2answers
WRONG REGION on the screen
Have you checked the region in your Disc Properties? Go into Disk Management, find your dvd and right click on it. Go into the properties and you will see a heading for Regions. In there it explains a bit about regions, which should be at 2. If it is not, then change it to 2. Let me know if this doesn't help.
1helpful
2answers
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Televison & Video Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
