Question about Just Wireless Bluetooth Headset Wireless Headset
BT-15K4 Pairing instructions
1 Related Answer
Anonymous
  • 5 Answers
SOURCE: bt-5
0000 Should do it
Posted on Feb 06, 2009
How do i connect to blue tooth. My iPhone 5 says make sure it is turned on and in range. I have checked both of these instructions but still it will not connect
Depends on the device you are pairing but most bt devices have to be put in pairing mode before they become vissible and pairable/connectible. Ussually the on/off button of the bt device has to be pressed and hold until a indicator led starts blinking.
Oct 25, 2015 | Cell Phones
HOW DO I PROPERLY CONNECT MY BT-15K4 BLUETOOTH TO MY IPHONE4?
You need to go into settings, then Bluetooth, you should see the device listed, just touch it. Sometimes they want a pass code, it's normally 1111.
Good Luck
Nov 25, 2014 | Cell Phones
Manual BT-15K4 Just Wireless Bluetooth
If you have not set up your bluetooth with a custom pass key then the factory setting is 0000.
Oct 08, 2012 | Radio Communications
How to attach a bluetooth headphone to laptop
normally, BT headset comes with instructions.. and cd for the BT driver if additional functionality is required. the pairing process is the usual normal one. post back if you need further guide
Aug 15, 2011 | Computers & Internet
I forget passkey of jebra 108 bt bluetuth
Most modern bluetooth headsets use the pin 0000, if older maybe 1234. Other than that I would consult the devices instruction manual under the pairing area.
Rylan
Dec 15, 2010 | Uniden BT-108 Bluetooth Headset
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Bluetooth pairing code for Intempo BT-01
The pairing code is 0000. Turn off your BT-01 then back on again. The blue light flashes quickly. Only during that time can you pair with it. Good luck, Andy W
Apr 30, 2009 | Audio Players & Recorders
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Just Wireless Bluetooth Headset Wireless Headset Logo
246 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
