Question about Mitsubishi WS-65907 65" Rear Projection Television
Cannot disable net command devices
Purchased a harmony 670 remote to control all my entertainment devices but during programming it would not operate with my ws-65907 until i deleted all devices associated with net command. could not find delete in set up menu as per harmony instructions, ie, open set up menu, select delete, select entire configuration, select next and follow on screen instructions.
Posted by dansady on
5 Related Answers
Anonymous
  • 934 Answers
SOURCE: Mitsubishi WS-48511 Device Screen Will Not Go Away
David,
Let's start with unplugging the set from the wall power for 15 minutes. This will hard reset the micro... While that's unplugged inspect the buttons on the front panel of the Tv to see that none are stuck in a pushed-in condition. Plug the unit back in, power it up and if all works okay you're back in business... If not, let try a keyboard unlock. Press and hold the "menu" button on the front panel for 10 seconds. You won't see any on-screen changes but then try to select an input from the buttons on the front of the Tv.
After you've done these drop me a note and if we haven't solved it will try some other things..
Bill
Posted on Dec 02, 2007
jomabug76
Josh Whitehead
  • 1148 Answers
SOURCE: Picture Convergence WS-65907
TRY NEW CONNECTERS AND INPUTS,,THEN USE THE CONVERSION
Posted on May 15, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi ws-65907 tv will not power on
one of the two pico fuses that protect the convergence chips this model uses is gone--see attached photo--
NEVER change just the fuses---if one of the two fuses is blown--the convergence chips got them-----
there are several ways to proceed from here-check the two fuses indicated in the photo and tell me if either or both are bad.
SD TECH
Posted on Jan 03, 2010
Testimonial: "SD TECH is Extremly helpfull and seems to know a great deal about TV repair. Thanks Again! "
Chi Chu
  • 8457 Answers
SOURCE: Hi, I have the ws-65907 65", it was working last
No,this problems is not the projection lamp problems.The tv now have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like 300-350 for parts and labors.
Posted on Oct 26, 2010
SD Tech
SD Tech
  • 14553 Answers
SOURCE: video is snow. no images just lines and snow. the
A suggestion: try with the original Mitsubishi remote to do the soft restore: Menu, 1,2,3, enter.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW WHAT YOU FIND.
SD TECH
Posted on Jul 05, 2011
Testimonial: "I talked to TV techs, family, friends and co-workers and no one had an answer to this problem. I tried your suggestion and it worked like a charm! "
Would like to program harmony 670 to go straight to HD channels with customized button. Can I?
Hi. I am not sure if the Harmony 670 has sequences, but I think it does!
1. In the 'Customize Buttons' page, click 'Add Sequence'.
2. Name yout sequcence someting (i.e. FOX)
3, Add the number commands you need
4. Click 'Save'
5. In the 'Additional Buttons' tab, type the name of the button (FOX)
6. Select 'Sequence' from the device drop down menu
7. Select 'FOX' from the command drop down menu
8. Update the remote.
tip
Harmony 670 Manual Download
Download Logitech Harmony 670 Remote Control Manual
Would you like a digital, searchable, pdf version of the Logitech Harmony 670 Remote Control Users Guide?
Have you misplaced your Logitech Harmony 670 Remote Control Owners Manual?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
tip
I hope that helps.
on Apr 30, 2010 • Televison & Video
Setting up my Wii system using Harmony 670 Remote
I just thought you should know the Harmony Remote is only able to control any device that uses infrared control. Unfortunately the Wii console uses Bluetooth technology which means the Harmony Remote would not be able to control it.
Hope this helps you!
-Kennedy
Need help with Harmony One remote and Mits WD-65736
To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
Open the Mitsubishi Television's setup menu.
Select Delete at the setup menu.
Select Entire Configuration and then select Next.
Follow the onscreen instructions to delete the entire configuration.
To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
#messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
tip
I hope that helps.
2helpful
2answers
Just installed Logitech Harmony 670 - Remote Query!
The Logitech will have assigned a button for that purpose if you selected the TV model number during setup. If one of the "soft" buttons was assigned it will be labelled on the LCD screen with the same name as the button on the original TV remote--something like Aspect, Zoom or Picture.
Need program codes for harmony 670
Your Harmony remote does not use codes. In order to program the remote, you must download the Harmony software, which you can download at http://logitech.com/myharmony. Once you have the software installed, you will be prompted to create an account and complete the setup.
Hope that helps.
I just bought a Harmony 670 Advanced remote, but no instruction manual. How do i program it to my TV and DVD? please help!
I can help you with your Logitech Harmony 670 remote control.
The Logitech Harmony 670 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony MAC Software Download
It has to be cleared after the software has been downloaded to your computer from the Harmony website.
Mitsubishi WS-65907 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
