Volume loss reduced volume on right speaker
Posted by drachmaninof on
Brian Sullivan
  • 27,725 Answers
Laptop or Desktop ?
Try swapping the speakers around to see if the problem is in the speaker itself.
Volume problems on computers often happen for a variety of reasons.
Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems.
Usually the problem isn't even an error but just merely an adjustment that needs to be made.
Test your speakers.
This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob.
Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this.
Check the computer volume level.
On the taskbar is a volume icon, which usually looks like a small speaker.
Click on the icon and turn the volume up.
Make sure it has not been muted.
Double clicking on the icon will bring up a panel of several volume controls.
Try turning up the volume on each slider.
Go to Control Panel and choose "Sounds and Audio Devices."
Under the volume tab, click speaker volume and turn up the level if needed.
Turn up the application volume. Most programs that use sound have an additional volume control just for that program.
Find the volume control and turn it up.
Usually it is located in the lower right or left corner on the program, but you may have to search for it.
Troubleshoot the sound card.
Download the latest drivers from your sound card manufacturer's website.
Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers."
Click on your sound card, select the driver tab and then click on "Update Driver."
Point to the file where you saved the latest drivers from the website.
After this, restart your computer.
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
If this doesn't solve your problem, try reseating the sound card into your computer.
Hope this helps
Posted on Nov 11, 2012
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
I want to reduce the bass on my logitech X-210 speakers.
Go to speaker icon bottom right corner of screen.
Right click and choose audio options
You should have sliders for bass,treble,volume etc
Jun 22, 2011 | Logitech X210 2 Speakers
Running four S70 Siroccos off the amp, everytime volume gets halfway the protection is cutting in with protection light flashing three times? When reducing down to two speakers amp cuts out three quarters...
You are overloading your amp. IMO 640A cannot handle heavy loads.
Better change the speaker combo and connect something that puts right load on the 640A. Else, get a meaty amp from CA.
Mar 04, 2011 | Cambridge Audio Azur 640A Amplifier
Volume adjuster stays on one level can not increase or reduce volume
The Potentiometer/switch (the rotary knob to adjust the volume) is probably faulty. The original is a 9mm B50K panel pot/switch. I'm on the hunt right now for a replacement.
If I can't get one, I'll have repair it using substitute parts, specifically an appropriately sized SPST switch for the power circuit and a regular B50K potentiometer to adjust the volume.
Feb 24, 2011 | Dell 5650 Computer Speakers
The right side of the speaker is low, you can hear it but it's like there is no bass to it like the left side, sounds like the right side is like whispering to you but the left side is talking normally,...
If your subwoofer is placed to the left side try moving it to the right side or try to move it in the center. Otherwise if you are using a PC go to the control panel and click the sounds and audio devices icon. a little window will pop up and the button labeled speaker volum click on and reduce the volume for the left speaker and then turn up the volume on your speakers and see if that helps.
Nov 30, 2010 | Logitech Z-2300 Computer Speakers
The receiver works ok until the vol is reduced and the right front channel drops out. Increasing the vol usually picks up the dead speaker but it drops out again when the vol is reduced. I've tried...
Make sure the audio level on the left and right channels are balanced. Check the menu for audio levels to adjust and make sure they are not maladjusted. If all levels are adjusted properly then the volume control or volume control circuity may be at fault.
Jun 27, 2010 | Sony STR-DE685 Receiver
The handsfree speaker sound volume and the
the speaker will need to be replaced
Apr 06, 2010 | Sony Ericsson K750
Volume problem
try reducing the output volume from the pc, maybe to about half or even a quarter of full volume. now increase the volume on speakers.
Mar 21, 2010 | Logitech X-540 Computer Speakers
How can I reduce the volume on my dell computer
on the bottom left hand side of your screen you will see a little thing that looks like a speaker right down near your time. double click it and your volume control will pop up .
Nov 16, 2009 | Dell Inspiron 1000 Notebook
102 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
