Question about Dell Inspiron 1150 Notebook
Usb not working,software ok,works with pci card adapter
  • Dell Master
  • 5,660 Answers
A) What makes you think the 'software' is OK? Windows may have lost the address to the DRIVERS; you want to believe Windows? Lol!
(Device Manager)
B) I would go to Device Manager, (Start > Right-click on My Computer > Left-click on Properties > Left-click on Hardware tab > Left-click on Device Manager)
Then click on the + sign to the left of Universal Serial Bus controllers.
Right-click; ONE AT A TIME, on each Intel USB Host Controller.
(Number/letters after each one.
Examples from mine;
1) Intel (R) 8280 1FB/FBM USB Universal Host controller - 2658
2) Intel........................................................................ - 2659
3) Intel........................................................................ - 265A
4) Intel........................................................................ - 265B
5) Intel........................................................................ - 265C
The Southbridge chip part number is Intel 82801FB { ICH6 }
Northbridge chip part number is Intel 915G )
Then left-click on -> Uninstall.
(Yes, a 'squawk box' will come up, "Warning you are about to uninstall this device". Whatever Windows! Click on OK )
Close all windows, go back to your desktop screen; and restart the computer.
(Start > Turn Off Computer > Restart)
When Windows has fully loaded again, you should see a 'pop-up' out of the system tray, "Found new hardware."
Plus perhaps another one, "Found USB Host controller XXXX"
Now go back to Device Manager, USB Host controllers, and do the same on the second one listed. Then go back, and perform on all USB Host controllers -> One At A Time.
(xxxx stands for the number/letter code )
You may also want to download, AND install the driver for the Chipset,
http://www.dell.com/support/drivers/us/en/19/Product/inspiron-1150
When I state download, I mean to -> Save File, Then DOUBLE-click right on the file name, AND install it.
Why Chipset driver?
Primer:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The motherboard chipset is what is indicated by the term - Chipset, on the drivers download page.
The motherboard chipset design used for your laptop, consists of a Northbridge chip, and a Southbridge chip,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[ CPU = Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
THIS is why a personal computer, should -> NOT be referred to as a 'CPU'. Shows ignorance, and is confusing ]
The Northbridge chip handles the Faster capabilities of a computer.
Processor, Ram Memory, and HIGH-speed graphics.
AGP, and PCI-Express are HIGH-speed graphics technology.
Integrated Graphics, and inserting a graphics card into a PCI slot; is NOT high-speed graphics.
The Southbridge chip handles the Slower capabilities of a computer.
1) Anything connected to the PCI bus. (One example is a graphics card inserted into a PCI slot, or Integrated Graphics )
2) Anything connected to the IDE bus.
3) Anything connected to the SATA bus
4) Anything connected to the USB bus
5) Ethernet
6) Audio (Sound)
Primer over.
The Southbridge chip is part of the -> Chipset
For additional questions, or to have me clarify anything stated above; please post back in a Comment.
Regards,
joecoolvette
Posted on Nov 11, 2012
6ya staff
SOURCE:
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
M3N78-VM LAN PORT& PCI PROBLEM
1) How do you know that PCI slot is not working? Tried another PCI expansion card in it? Perhaps another LAN adapter card?
(Ethernet Card)
A LAN adapter card will go bad before a PCI slot will.
2) PCI expansion slot is bad? No other PCI slot to use?
Then here is a suggestion,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3504463&csid=_61
Plug it into any available USB port on the computer.
It is a GigaByte Ethernet solution, also. (10/100/1000)
Regards,
joecoolvette
Aug 08, 2012 | ASUS Computers & Internet
Where can i buy a onchip usb2?
FIC FR33E motherboard?
http://www.ebay.com/itm/FIC-FR33E-L-MOTHERBOARD-CPU-LOT-10-/170633274365
Reference: Photo
To the far left side of the motherboard, is actually the Bottom of the motherboard, when installed in your computer case.
The two White long expansion slots you see, are PCI expansion slots.
If one is available, (Open), you can use a PCI USB adapter card.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4143850&CatId=511
Seem cheap? Nope. Good quality also. (You can also check the reviews)
Need guidance in installing?
1) Follow Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside the computer.
Computer on a table, computer unplugged from power, computer case open.
[Note* Always unplug the power to a computer AT the surge protector. NOT at the back of the computer. (Power Supply)
You can cause a power surge ]
2) TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
3) Finding an open PCI slot look at the back of the computer. In the metal frame you will see slots going horizontally.
These are Expansion Slots.
You may have an add-on adapter card already installed, in one of the PCI slots.
The expansion slot cover for it is removed.
You should see expansion slot covers however, in the remaining expansion slots on the back of the computer metal framework.
Remove the one that corresponds with the PCI slot you wish to use.
Be aware that the PCI slot will not be directly in line, with the expansion slot.
When installing an add-on adapter card, you will see when the card is inserted in the PCI slot, the metal bracket on the add-on card, lines up with an adjacent expansion slot.
This will make more sense to you once you go to install the card.
[PCI USB adapter card is an add-on adapter card ]
Line the card up in the PCI slot. Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Also, at the same time line up the metal bracket of the PCI USB adapter card, with the metal framework of the computer case at the back.
Gently push the PCI USB adapter card down into the PCI slot.
Fasten the card's metal bracket to the computer's metal framework.
Post the computer manufacturer name, and model number, if you need guidance in opening the computer case. Post in a Comment.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | FIC Computers & Internet
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
4 port high speed usb 2.0 pci card. when i install the card in my gx 260. it finds the card. but then mouse freezes and nothing else happens. have tried several times.
maybe the pci card have any problem that conflicts with your mouse,so try that to another computer,or myabe that pci card is now with that operating system " check the OS available"
Jul 16, 2011 | StarTech.com 7 Port PCI High Speed USB 20...
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Pci card doesint work
What you want is a USB hub.  That will allow you to connect more than two USB devices to your computer.  There are two types, USB 2.0 and USB 1.1.  USB 1.1 will work for most slow speed devices, USB 2.0 is better for cameras and hard disks that have the support.  You should confirm which version of USB your computer has, but you should be OK getting a USB 4-port hub, plugging that into your computer, then plugging your keyboard and mouse into the hub and using the other port for the new peripheral that you wish to install.  Old PCI cards are problematic because you need the correct drivers.  You also need to make sure you plug them into the proper PCI port.  It sounds like the device you got from e-bay might be bad, so you shouldn't continue to use it.  If you post the make / model of your computer we might be able to suggest a new PCI card that will work if you still want to add more ports to your computer.
Apr 21, 2009 | VIA Vectro VT6212 (A62124) Serial Adapter
Parallel dongle will not work with new system that only has USB connections
The dongle only works with a standard parallel port, not a USB parallel port adapter, It may be possible that a PCI parallel adapter card will work with the dongle. Check it first with the supplier and or software supplier of Designer 1.
Apr 16, 2009 | Computers & Internet
Speakers not working
That means that the audio card is either faulty, or the driver software for the audio card must be reinstalled.
To find out if it is the software, reinstall the software using the computer install disk.
If you do not have the disk you can download the drivers from manufacturer website.
If the card is faulty, that is because unplugging in a bad way caused a short or broke the jack socket solder joint on board.
In that case buy a replacement
Either external USB : StarTech.com USB 2.0 to Audio Adapter Sound card
Or internal:6 Channel PCI Audio Sound Card Adapter for .
Audio cards are not expensive and you can buy a new one with a small fee.
Mar 22, 2009 | Computers & Internet
Dell Inspiron 1150 Notebook Logo
50 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
