Question about Kodak EASYSHARE 5100 All-In-One Printer
Print is faded or blank
When I print anything from my computer the ink seems faded and disappears in entire sections. IF I copy something or scan it that does not happen. I have cleaned the print heads several times already and for some reason it just won't print clearly from my computer. Any suggestions? Thanks
Posted by Julie Schroeder on
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: Kodak easy share5100 will not print,copy from computer properly
Calibration needs to be run if you have not. if you have...
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead and free inktanks.
or if you dont want to wait on the phone....
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipe many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove the printhead from the printer. put the tanks back into the printhead. Be very carefull not to drop the printhead and do not put the printhead on a table with the nozzle plate down (where the ink comes out). take the hand wipe fold it a couple times. Gently wipe the printhead nozzel plate in the direction of the lines on the nozzle plate do not do a circular motion or wipe against the grain. you may not even have to use a wiping motion. you can just place the wipe on the nozzles and let the printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
I used my printer to do a photo guest book at my sisters wedding it turned out great (i wipped the printhead before i started all the pictures look perfect!)
SDtester.
Posted on Oct 15, 2008
Anonymous
  • 40 Answers
SOURCE: Kodak Easyshare 5100 Wont Print In Color Or Black
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-421-6699cb_transparent_r.gif.
Posted on Nov 20, 2008
Anonymous
  • 214 Answers
SOURCE: Constantly cleaning the print head
I feel you should take it back. Under warrantee?
Posted on May 01, 2009
Anonymous
  • 952 Answers
SOURCE: print head clog and I use half my ink unclogging them
Thanks for using FixYa!
There is indeed another way to unclog your print head without wasting ink. All you need to do is to take out the cartridge then get some alcohol (not liquor but the antiseptic type like ethyl or isopropyl used for treating wounds or cleaning stuff) drop around 3 drops of alcohol into the ink inlet and leave it overnight. This should declog and clean the print head. I hope this helps because it did work for me.
Have a nice day.
- HotRatchet
Posted on Aug 01, 2009
Anonymous
  • 295 Answers
SOURCE: black ink is faded
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
Posted on Sep 21, 2009
When I run anything through the rollers I get a black line down my copy/scan. How do I fix this? I have cleaned the rollers and it didn't fix my problem.
only thing I know is when my copier/printer was doing this it was from refilled ink cartridges. if you are using refilled try replacing with new ones.
Sep 22, 2015 | Epson WorkForce WF-3640 Wireless Color...
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
My Kodak ESP 5 fades when printing then will go blank even when I have ink
try copying something from the printer in standalone mode and check if the same issue or not.....if it is then try and do print head cleaning from the menu option and if still does not resolve call kodak tech support as it is print head issue and needs replacement..........if the copy comes out fine and faded print is only when trying to print from the computer then it could be a software issue
Jul 01, 2009 | Kodak ESP 5 Printer
Photosmart C3180 not copying properly
mke sure there is no sticky tape on your inkjets
Apr 20, 2009 | HP Photosmart C3180 All-In-One InkJet...
When I put an original on the glass to copy, copies come out blank but cartridge has not run out
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity and therefore it is not taking an accurate picture.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. Do you have the same issue when scanning?
If it happens when you scan and it is plugged into the wall and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jul 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Big Black not printing
Sounds to me your print head is plugged up. This is not usual though because the majority of people use black ink much more. So, in your printer utility, do a deep cleaning. If that does not work, there is a thing called a purge unit in it. This is a usual way of draining waste ink to a pad that soaks it up. if the hose, or other parts are clogged, it backs the ink up and causes the print head to clog. If this is the start of it, do not waste your ink cleaning, and try not to let it sit too long. Contact canon, and let them kno what you think it is.
Oct 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
56 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
