Question about Kenmore Elite 44173 30 in. Electric Cooktop
Kenmore elite electric cooktop error code eo 11
3 Related Answers
Anonymous
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
Anonymous
SOURCE: kenmore elite 36'' glass top cook top beeps and displays eo 11
so does mine
Posted on Oct 02, 2010
Panchote
  • 92 Answers
SOURCE: I need black control knobs
Here is the link. http://www.searspartsdirect.com/partsdirect/brands/Kenmore-Parts
Posted on Jan 12, 2011
I have a Kenmore Elite Electric Range with Induction Cooktop #C970-440032 with an error code E074
Suggest down load the owners manual online and reference error codes.
Mar 21, 2018 | Kenmore Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Kenmore Elite oven error code SAb what is this?
I think you have entered "Sabbath Mode" which blanks the display ... check your owners manual to see how to exit this mode.
Jun 23, 2010 | Kenmore Elite 44173 30 in. Electric...
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Kenmore electric cooktop not working on low eat
If it was the burner element it either would work or not (no in between)
It has to be the switch
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Kenmore Elite 44173 30 in. Electric...
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
Kenmore Elite 44173 30 in. Electric Cooktop Logo
808 people viewed this question
Top Kenmore Cooktops Experts
jdthefixer
k24674
Jorgie Navito
Jorgie Navito
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
