When i try to start it, it sounds like its running like it wants to try to start but it isnt kicking over. i think it might be the starter but how do you know if the starter went out ? It is getting gas, power, the fuel pump is pumping. HELP..!!
SOURCE: guardian primepact 50g rv gen starts for 2 sec then shuts down
This story ends with bad gas and silicone in the gen tank
SOURCE: guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
SOURCE: generac 4000xl carberator keeps flooding, engine
You have a problem with the carb float valve. It is no longer sealing causing fuel to continue to flow into the float bowl after it is full. It may be dirty, out of adjustment or just need to be replaced because old and worn out.
SOURCE: I have a new Guardian 40G generator that won't
Try to measure the voltage at the connector when trying to start.
If it is 12 V and the engine does not start - disconnect it and try again.
Have in mind that you must have protections (Shut down):
and this valve may be responsible for them.
SOURCE: My generac 40g rv generator will start fine but no
It may be demagnetised. If you turn off the generator before unplugging the load this may happened. Try to put a strong magnet (like those from loudspeakers) in contact with the body of alternator. I do this in the past and it work.If you do not know how to do this ask an electrician, he can help you .
