Polaris Pb460 Polaris Booster Pump Replacement O - Ring Logo
Posted on Nov 10, 2012
Poloris 500 sportsman water pump leak, new seal
Replaced water pump seal still leaks out port hole
4 Related Answers
john224
John Prohaska
  • 1378 Answers
  • Posted on Apr 13, 2010
SOURCE: Softub about 4 years old - I have a leaking water
Thank you for posting your question here on Fixya.com.
Neither...it is threaded onto the motor shaft. Lock the shaft at the end opposite the impeller and turn it off counter clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Testimonial: "Thanks John - very helpful"
Anonymous
  • 990 Answers
  • Posted on Jul 19, 2010
SOURCE: I recently replaced the impeller shaft seal due to
Check your finger screen inside the wall fitting where your hose hooks up. Also check the impeller to be sure nothing is inside the vanes.
czaa
Arnie Burke
  • 7339 Answers
  • Posted on Oct 21, 2015
SOURCE: I have transmission fluid leaking out of hole in clutch cover where the pull start rope goes in. Is that normal on a Polaris sportsman 500 ho.
Gasket or a bolt is loose. Dont use til u fix. Get a manual by clymer etc for repair details...utube is helpful
Lawrence Oravetz
  • 10558 Answers
  • Posted on Jan 04, 2017
SOURCE: 2004 Polaris 500 ATV. Changed water pump Now it leaks out weep hole. Any answers
The new pump shaft seal is no good. Get another pump.
I have a 2006 ford 500 sel the water pump has water coming out of it do i need to replace the water pump or is there a seal or gasket that may have gone bad? That i could replace
Most water pumps have weep holes underneath that direct leaking water downward.
Sounds like you need to replace the water pump and of course get a new gasket. don-ohio
Signs bad water pump
Water in the oil which would look like chocolate milk. Oil in the cooling system which would look like tar or black dots floating in the coolent. Or a visible leak of coolent on the floor or ground. After checking the hoses and related gaskets for leaks look at the weep hole on the water pump. If there is coolant around the hole then the pump seal is bad.
How do I repair a leak coming from water pump gasket?
If it's leaking from the gasket you'll have to replace the gasket. If coolant is leaking from the hole in the water pump body the water pump seal is leaking. The pump will have to be replaced if the seal is leaking.
1helpful
I have an oil leak from a drain hole in front of engine.what could be the problem?
If the oil plug bolt is leaking you need a new aluminum sealing washer. There are no oil weep holes in the front of the motor. Is it the weep hole under the water pump? You probably have a bad water pump seal or a bad oil seal on the water pump shaft. Buy a new water pump and the K&L water pump gasket kit. The K&L gasket kit comes with all the gaskets, seals, and washers necessary to do the water pump replacement for a fraction of the cost of the OEM Honda individual gaskets, seals, and washers.
2answers
Leaking anti freeze from water pump
the water pump has 1 or 2 weep holes on it when the seals go out the antifreeze will leak from them holes replace it and no leak. get back to me with a make and model and year for replacement info.
2helpful
2answers
I have antifreeze leeking out a pin hole under the water pump
It is very likely the water pump seal. It is always a good idea to replace the bearing while you have it opened up.
Water leaking out the bottom. not from hoses
Depending on the age of this machine, and if it is a GE product, it could be leaking from the pump. If it has a 4 port pump there is a small hole for venting in the pump and once the seal inside deteriorates it will leak. You can't buy the seal on its own you must replace the pump. The part number is WH23X42.
Replaced water pump for the 5th time and it leaks from the hole u
No , it's not normal to leak.
Either , water pump is bad ( 5 times ? )
or instalation was bad or more likely , leak is not the water pump at all
your belt is to tight and your burning up bearings ease up on tension. use 3/4 inch play at least
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Sean Wright
Sean Wright
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
