I dropped the camera in a soft sided case. When I press the shutter release with the camera on, the mirror moves up and stays up. When I push the shutter release a second time the mirror moves down,then moves op, the shutter releases, and then the mirror moves down. If I press the shutter release a third time, the mirror moves up and stays up.if I press the shutter release a fourth time the cycle continues. No pictures are taken however.
Hi petebenedict, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
please tell us what shutter speed setting the camera is set to. Is it possible that you have a very slow setting selected so the camera is trying to take a photo with a long exposure? Or that the auto setting is set auto, but the lens cap is preventing enough light to take a photo - thus a very long time between shutter opening and closing??Hi petebenedict, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
I removed my lens and put it back on making sure that the aperture ring was set properly, that did it. The second time, I locked the aperture ring back in to its proper place and it worked fine.
There may be something wrong with the camera. Make sure it is set to Single Exposure setting and not Multiples. There should be a control on the top left to change this. Look for an "S". this is what you want. If that doesnt help, you may need to get it repaired.
OK, first off charge your battery and try again. Probably won't do anything but low power does cause problems. Second, check to make sure the mirror isn't stuck on its stop. If it doesn't move up and down freely, there may be a problem with the mirror. Finally, usual cause is motor failure in the aperture unit or shutter failure. If you can lift the mirror, lift it gently and make sure the shutter blades are laying flat. Unfortunately Nikon stopped selling parts over a year ago so you would have to send it to Nikon.
There is no dedicated mirror lock-up button, the self-timer does move the mirror out of the way when you press the shutter release and the shutter fires ten seconds later.
most likely cause is failure of the motor in the SQ unit on the side of the mirror box. This ***** the shutter, raises the mirror, and operates the aperture unit. They're made in China, motors are **** This is a very very common problem, and the part is always on back order at Nikon. As Nikon has announced that they are going to stop selling parts - to anyone - in a couple of months you are probably better off sending it to them. Be prepared for a bill a little less than $200.
also if you pressed down really ******* the release to get it to fire, you may also have broken the release switch
hiit is not easy to tell what exact problem. It has quite of causes in your case. But I can only tell most common cause that it is sequence unit fail. It could also other like shutter fail, mirror box mech fail, motor fail, control pcb fail, and so on...etc...I recommended you bring to your local service place or Nikon service center which is helpful to you.
Try pressing and releasing the shutter button. If that doesn't do anything, then turn the camera off and on and press and release the shutter button. If that still doesn't do anything, then turn the camera off, remove and reinsert the batteries (or a fresh set, if readily available), turn the camera on, and press and release the shutter button.
I ran across a Nikon N80 last week which hadn't been used for many moons. I tried the shutter and the mirror promptly locked up. It took about half a dozen tries, but the mirror eventually shook loose or whatever, and the camera now works perfectly.
If the above procedure doesn't do it, then you may have to take it in to a good camera shop for a CLA (clean-lubricate-adjust), the camera equivalent of an automobile tune-up.
You are correct, there is a setting. Press Monitor, then Menu to get to the menu; go to the thitd menu option (looks like a pencil), select option 4 (AF Activation) and set it to ON (Shutter/AF ON). This will solve your problem.
By "stayed up", do you mean that the mirror remained in the up position so that you could not see anything in the viewfinder or do you mean that the shutter actually remained open? I do not remember the exact features on your camera, but in general, this is what I would do.
1) Remove the film from the camera and take a picture. Note if you see anything in the viewfinder. If you see nothing, the mirror is in the up position. Verify this by removing the lens and opening the door on the camera back. Look through the lens hole. If you can see through the rectangular hole at the film plane, the shutter is open. If instead you something is obstructing the hole, the shutter is closed. In any case DO NOT TOUCH THE SHUTTER! The shutter is what is covering the hole.
2) If the mirror is in the up position, check to see if your camera has a feature that allows locking the mirror in the up position. Some cameras have this feature to allow use of lenses with very short focal lengths. If this is the case, simply unlock the mirror.
3) If the shutter is the problem, your shutter speed may be set to "T", which stands for time. In the time exposure mode, you press the shutter release once to open the shutter and a second time to close the shutter. Cameras with a "T" setting also have a "B" setting, which stands for bulb. This is a throwback to the old days when it was common to use air-powered shutter releases rather then cable releases. The bulb was a rubber bulb that you squeezed to force air through a tube and push a pin to activate the shutter. The "B" setting keeps the shutter open as long as you hold the shutter release in, but as soon as you take your finger off the shutter release, the shutter closes. Both of these settings are used to make timed exposures. If you find that the problem was that the shutter was set to "T", set the shutter speed to 1/25th second or so and try again. The following sequence should occur; the mirror will flip up and the viewfinder image will disappear, the shutter will open for the prescribed time and close, the mirror will return to the down position and you will again see through the viewfinder.
If this does not work, you may need to take it in for repair.
I had the same problem. I sent my camera to the Nikon Service Center. They fixed it within three days. They actually replaced the whole aperture frame. FREE OF CHARGE AS LONG WITHIN THE WARRANTY PERIOD.
