Question about Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio
Connex 3600hp problem with channel selector
When i turn it on channel selector rotates and then stay cant acess channels
1 Related Answer
Ironfist109
Iron
  • 3018 Answers
SOURCE: Connex 3300 HP won't change channels when you turn
There is a board in the CB called a PCB board. If you open your radio it is a little circuit board. Held onto the side of the radio by a screw and has two or three connectors leading to the board. Replace that little board and your radio will be good as new. I have seen radios come in my shop many times and this is the fix. What that board does is send a signal to the crystals to start mixing a frequency. When it goes out it just sticks where it is at. Here is a link to a place that can take care of you. http://www.hyelectronics.com/default.asp You tell them you need the little PCB board for a Connex 3300 inside the radio. Might be $35 or so.
Posted on Mar 18, 2011
Convert 11 meter to 10
you would need to take to a cb shop. if you never done this before.
its simple process..
should cost less then $25 to have someone do this. correctly.
they should even setup and tune it for that price also.. so its ready to go. tune ups should be free at a good shop. and there shouldn't be any bench fees involved. just saying. or thats how the shops are here in TX. anyways.
Jan 03, 2015 | Connex CX-4300HP CB Radio
Why does the red light for antenna stay on
This means that your swr is high. you can damage the radio using it in this condition, check antenna and coax for damage or misinstallation
Feb 27, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
I have a connex cx-3600hp cb and it sounds like it has no power
your power switch it faulty as there is a drop in voltage
does the meters dim down?? then the voltage supply past the power switch it dropping as it draws more current or... the audio ic has damage or one of its associated capactors sometimes a diode can become leeky its used for AM modulation also
Feb 25, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
I BOUGHT THE CX 3600HP 2 YEARS AGO. IT WOULD STOP WORKING FROM TIME TO TIME AND NOW IT WON'T WORK AT ALL. WHO DO I CONTACT ABOUT SENDING IT BACK FOR REPAIRS
Great Question. I'm not sure if Galaxy would work on a Connex . Copper Electronics has a repair department and would probably fix it for you. I'd offer but I don't have a lot of spare time right now. It's probably the power connection inside of the radio or one of the legs on the main volatage regulator broke loose from the pc bpaurd. That's a common problem with those radios.
Feb 20, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
Need more receive
Use a longer antenna or get it higher..
102" whip for mobiles.
maco v 5/8, army big stik, or Bandit for base. or a long beam 5 or 6 element type.
for example..
May 05, 2013 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
The channel selector will not come on
REPLACE THE TINY BULB...DUH, use a meter to determine positive a neg on supply, hook up backwards and you may blow the bulb..
Aug 10, 2012 | Connex 3400HP Amateur Radio
Connex 3300 HP won't change channels when you turn ch. selector stays on same channel ch. 32.
Mar 14, 2011 | Connex 3300 240-Channels Base CB Radio
Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio Logo
123 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
