Whirlpool washer CA2000XMO0 Coin operated ...bought in 1982...has been used as only washer in 8 plex. The problem is that after putting in the new motor and timer the basket spins while agitating. The lid latch is not working ...don't think that is the cause. The clothes gets twisted and throw water ands soap out. Can't find anything on the internet with that problem...seems to be unique. Could it be the timer?
SOURCE: Basket spins while agitating
transmission defective...not a special problem,,,the transmission shot...
SOURCE: spins while agitating...only after new motor and timer
not that unique, whats happening is the transmission has a wig wag and shift cam bars that are not moving at the right time. you probably have an open coil on the wig wag and its normal for them to do this when a coil fails. just take the 5/16 screw out of the wig wag and lift it off the plungers, then replace it with a new one. all should work correctly after that.
SOURCE: spinning basket while agitating
SOURCE: would a new basket drive help?
ok so now i have seen your ? 4 times and you dont need a basket drive either.
you might want to make sure you didnt unhook a wire from the wig wag when you changed the motor and it could also be the cam bars are just stuck, which ever, just look at the wig wag and bars. that will be your area to repair.
