I have a Pioneer DVD player Model dv 366 s which was purchased in year 2003. It is a plays 5.1 / DTS cd. I have connected it to my Denon amplifier Model 1604. and have hooked to my 29" Sony TV. I do have a HT system, comprising of 2 front, 2 rear, 1 centre and a subwoofer. When I play a DTS dvd disc, the sound comes only from the connceted speakers and not from the TV set. Is there any specific reasone for this. I have tried several DTS dvds, but all respond in the same manner i.e. no sound from the TV. Pleas let me know if there is any technical reason for the same.
Regards
JAYANT, Mumbai, INDIA
SOURCE: No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Posted on Oct 06, 2007
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
SOURCE: Pioneer DV-260 DVD player cannot play HD DVD
thats like trying to play a dvd ina cd player. cant be done.
Posted on Nov 17, 2008
SOURCE: When i play music cd
What is happening is the the pioneer is set up so that you can choose how you listen to your DVDs. So first you must see how your DVD is connected via the audio. I am fairly sure that the Default on the Pioneer is to play it through the standard stereo if all you have plugged in is the left and right audio plugs. If you buy an optical cable or a plug in the Digital Coax out put to the pioneer receiver, then the pioneer will decode the sound and out put true surround sound. Some DVD players don't have a digital out put, but these are the cheapest ones out there. If yours doesn't have a digital out put, then you need to get one that does. They can be purchased for as little as 39.00.
Okay lets assume you bought a DVD player with Digital out put for audio and you have it connected to the receiver. Now, you have to change the mode on your pioneer to let it know that your audio is coming in DIgital when you select the DVD. (Though this may already be the case and you won't have to do anything once you connect it.)
Posted on Dec 12, 2008
SOURCE: No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Posted on Feb 08, 2009
